Power Specifications - Full Range Channels
RMS Power @ 4 ohms 70 watts x 4 channels
RMS Power @ 2 ohms 90 watts x 4 channels
Bridged RMS Power 180 watts x 2 channels
Amplifier Specifications
Amplifier Class AB
Number of Channels 4
Total RMS Power Output 360 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 2 ohms
THD at Rated RMS Power 1%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 50 - 200 Hz
Low-Pass Crossover Frequency 50 - 200 Hz
Signal-to-Noise Ratio 100 dB
Bass/Gain Remote No
Fan Cooled No
CEA-2006 Compliant No
The above are the specifications of the JL amp; It says I can bridge 4channels to make it two, also it has a high pass and low pass filter.
So it is possible to bi-amp speakers correct?
EDIT
Is this Possible ?
HU ---> JL Front ---> Amplifier (bridge Channel 1&2){set HPF on the amp itself}---> Passive Crossover---> left front woofer+tweeter
HU ---> JL Front ---> Amplifier (bridge Channel 3&4){set HPF on the amp itself}---> Passive Crossover---> right front woofer+tweeter
In simple terms can i use 2 channels of the amp to power a single speaker ? (Connected the same way as i would have if i used only 1 channel)
2. You can connect the Front Right and Left to 2 channels (1-2) of a 4 channel amp and Rear Right and Left to the other 2 channels (3-4) of a 4 channel amp.
I do not want to do this as I intend to purchase only the front pair of speakers.
Let me explain to the best of my abilities what I intend to do
HU-->JL Clean sweep front channels (2 channels)--> 4 channel amp--> front speakers (channel 1&2 for one speaker, channel 3&4 for the other speaker)
HU-->JL Clean Sweep rear channels (2 channels)--> Mono amp --> 12" Sub Woofer
I do not need the rear speakers as I will be driving alone 90%of the time.
Also can i connect rear speakers directly to HU by avoiding the JL clean sweep altogether? In case i want to retain the stock speakers at the back.
