Old 17th October 2007, 23:28   #406
FATAL3RROR's Avatar
Originally Posted by kumar_ranjan View Post
@FATAL3RROR: I think you also have Ground Zero Titanium GZTW 30T Subwoofer.
oops i missed that out! thanks for pointing it out ranjan!
FATAL3RROR is offline
Old 19th October 2007, 10:33   #407
SRShrikanth's Avatar
Originally Posted by ceebeezee View Post
1. Car
Swift VDI (ABS)
2. & 3.what is your existing setup (HEADUNITS, SPEAKERS, AMPS, DSP,SW etc.)? How much did it cost ?
Head unit : Blaupunkt Hamburg MP57 - Rs.13,500 (MRP - Rs. 15,950)
Front : Blaupunkt GTx663 3 way - Rs. 2,500 (MRP - Rs. 2750)
Rear : Blaupunkt GTx 693 3-way ovals - Rs. 3,000 (MRP - Rs. 3450)
Total : Rs. 20400
4.How serious were your about your system?
Pretty serious
5. which kind of music do you listen to ?? prefer deep bass or how is it...
English - Golden oldies - everly bros, elvis, marvelettes, etc etc
Bollywood
English Rock
Instrumental - Carnatic
6. would you recommend it to others???
Yes, - the HU comes with Front Aux, USB AND in-built Bluetooth for Handsfree (the mike gets attached to the visor above the driver)
Hey CeebeeZee,
Where in Bbay was your ICE unit installation done.?
How practical is the use of the bluetooth enabled mike for the handsfree.
This Q's has particular reference to long drives and loads of talk time in between. So is this set-up more effective than an In-Ear bluetooth set that has serious battery-time issues.?
Look forward to hearing from you.
Cheers,
SRShrikanth is offline
Old 25th October 2007, 14:34   #408
prabhuav's Avatar
Thanked: 128 Times
mah scorpio - ICED
1. Car
rather Truck: 2007 Scorpio DX
Headunit: Alpine CDA 7894 - bought used in the US for 170$
Amp : JL Audio 6450 6 channel
Sub : JL Audio 10w0.8
Both together bought used in the US for 300$
Front: Alpine SPR 17LS ( Rs 10300) on the front door , with 3 inches of spacers
Rear: Polk DB 4x6 coaxials (Rs 3600) in the stock location with 1.5 inches of spacers
Power Cable: 4 guage Pyle..(Rs 1400) wanted Audison but didnt get.. Will upgrade later.
Fuse box and ground connecter - (Rs 800)
Speaker Cables: Scosche EFX (Rs 3750)
RCA interconnects: Monster (Had them - originally cost 35$ x 3)
After a lot of deliberation on where to mount the sub, finally decided to put it in a wedge box in the back. This came with the sub - free
Installation by TMC - (Rs 2000) All connections soldered and heat shrunk sleeves - no insulation tape for me... Total cost approx 41k
Pretty serious
English Rock
Ghazals,
Bollywood - when I am subjected to it by the women in the house
Hell Yes, - But sourcing all this new in India will add another 20k to the budget
prabhuav is offline
Old 25th October 2007, 18:47   #409
Hi Saurah,
Am currently evaluating a basic ICE set-up for my Indica Turbo. Stumbled upon your basic set-up and wanted to know your experience with it now.
Have you also done some basic damping as well.??
Look forward to hearing your views as it will help in my decision making.
Old 30th October 2007, 12:43   #410
kumar_ranjan's Avatar
Thanked: 19 Times
Swift Iced
1. Car
Maruti Swift VXi
2. what is your existing setup (HEADUNITS, SPEAKERS, AMPS, DSP,SW etc.)
Head unit : Pioneer DEH-P80RS
Front : Illusion Electra EL6.1
Rear : Illusion Electra EL 62
Sub-Woofer: Ground Zero Sub-woofer Titanium GZTW 30T
Amplifier for Comps and Rear: Ground Zero GZTA4.120MK2
Amplifier for Sub-Woofer: Panasonic CY-PA2003U
Wiring: Kickers Speakers and RCA Cable, Ichibahn Street Series Interconnect cables
Installation at Sound Craft, Oshiwara (Mumbai)
http://www.team-bhp.com/forum/sound-...-part-2-a.html
3. How much did it cost ?
72k so far
Pretty serious
Jazz, Rock, Pop and any soft music
Yes, absolutely!
kumar_ranjan is offline
Old 30th October 2007, 14:57   #411
Here's to all veterans of ICE and this unique knowledge-sharing community here.
1. Car
Indica Turbo 2007.
Head unit : Blau Bremen 76 ( $425 - purchased in the US )
Front Dash : Blau Velocity 132 Component Spkrs
Front Door : Blau Velocity 172 Component Spkrs
Rear Parcel Tray ( MDF Plank ) : Blau OD series 6x9 3-way coaxial
Amplifier for Comps and Rear: Blau GT series ( under consideration )
Wiring: Blau Stock cables
Installation : Auto Sonics, (Mumbai)
Damping : Wuerth Sound Deadners ( 1.5 packs i.e. 9 sheets used )
INR 28.5K so far.
Serious enough.
South-Indian Classical, Western Instrumental, Slow Rock & Global Fusion sounds.
If clear crisp sound at bench-marked budgets are for you - hear the violins whistle through.!!!
Old 30th October 2007, 17:45   #412
iraghava's Avatar
Thanked: 272 Times
Two sets of components in the front, that too Velocity? Isn't the sound really shrill?
iraghava is offline
Old 30th October 2007, 17:56   #413
The two Blau's in front , especially Velocity - have given my exceptional clarity for the 60% instrumentals that i play.
The amp maybe discounted for this set-up - unless required.
I havent found it shrill yet, maybe its the placement of tweeters that have led to good acoustics here.
So farr...so good.
Old 30th October 2007, 18:52   #414
Thanked: 877 Times
I think he is running both sets off the HU. In this case, as he has no amp right now the HU may not be able to provide enough power for higher volumes. So he must have compensated by running two sets of speakers, but I don't understand why he chose to buy two sets of components instead of spending the money on an amp.
And I am using the VPC172 in my car. I don't find it overly shrill ( I can remember the days when I had the infamous TS20s :shivers: )
akg7091 is offline
Old 30th October 2007, 19:28   #415
Technocrat's Avatar
Thanked: 2,702 Times
So in all there are two sets of Tweeters in front ??
Technocrat is offline
Old 30th October 2007, 19:30   #416
Yes Gentlemen,
I am currently running everything off my HU and hence there is an evident lack of power at higher volumes.
However, my taste of music luckily revolves around softer kinds and the distinct effect of dual components only helps my cause.
With time and some Vitamin - M, an amp will also become part of this set-up.
Until then, its just the sweet sound of music. Noise for later.!!!
Old 30th October 2007, 19:33   #417
Indica Turbo ICED
Two sets of Tweeters - Yes.
One set off the corners of the dash.
One set off the roof, behind the rear seats.
That seems to work wonders for now.
Old 15th November 2007, 11:35   #418
surajs's Avatar
Thanked: 15 Times
1. Car
Swift VDI
Head unit : ALPINE 9881 - Rs.12,800
Amp : ALPINE MRV-F345 - Rs 19800
Front : HERTZ Energy ESK 165 2 way - Rs. 9,100
Rear : HERTZ Dieci DCX 165 - Rs. 3,700
Sub : HERTZ ES300D (Sealed) - Rs 9100
Cables : Rs 3000
Damping : Rs 5000
Total : Rs. 62500
Pretty serious
Indian,English Rock etc
YES...!!!
surajs is offline
Old 16th November 2007, 17:44   #419
jkdas's Avatar
Thanked: 1,492 Times
Originally Posted by surajs View Post
1. Car
Swift VDI
Cables : Rs 3000
Damping : Rs 5000
Total : Rs. 62500
Pretty serious
YES...!!!
a case of what TBHP ICE section can do to you
.... overshoot budget!
2nd Hertz + Alpine install at Tvm. Executed by Zuhemi (Emperor Cochin)
jkdas is offline
Old 16th November 2007, 18:31   #420
hydrashok's Avatar
Thanked: 18 Times
@surajs, that was fast! Posted the specs the very next day after the install huh?
Congrats on the install! I'm, sorry I couldn't be there. I heard it sounds great!
hydrashok is offline
