Thanked: 42,671 Times
| Re: ARTICLE: Extended Warranties. Yes or No? Guys, need an honest suggestion. When I bought my XL6 in 2020, I bought EW without any second thought. Then came a rude shock that if I get it serviced at my trusted MASS, it won't be eligible for warranty claims. NEXA cars need to be serviced at only dealer(Arena/NEXA) workshops, with whose work I'm largely dissatisfied.
Also when one looks at EW Terms and conditions, it's quite weird and Maruti has mentioned almost everything under which they can escape. I've mentioned in BOLD all clauses using which they can legally deny me replacement of expensive parts. This is their EW T&C: Quote:
Warranty Conditions & Coverage
MARUTI SUZUKI EXTENDED WARRANTY COVERAGE:
If any defect(s) should be found in the Maruti Suzuki vehicle within the extended warranty coverage period in
electrical/ mechanical part, Maruti Suzuki’s only obligation is to repair or replace at its sole discretion any part
shown to be defective, with a new part or the equivalent at no cost to the owner for parts or labor. Such defective
parts, which have been replaced, shall become the property of Maruti Suzuki. The owner is responsible for any
repair or replacements that are not covered by this extended warranty
The Extended warranty is subject to the following terms & conditions:-
1. Extended Warranty registration form & certificate of extended warranty registration
The Extended warranty registration form & the certificate of extended warranty registration forms a part of
contract between Maruti Suzuki India Limited and the owner of the extended warranty of the vehicle as per the
details mentioned on the extended warranty certificate.
2. Limitations:
a) Default in getting the vehicle serviced as per the stipulated kilometers and time period as mentioned in the
Owner’s Manual and Service Booklet.
b) The vehicle must not have been used for competition or racing.
c) The vehicle must not have met with accident.
d) The vehicle must not have been modified or altered, including without limitation, the installation of
performance accessories.
e) The vehicle must not have been fitted with any parts or accessories not approved by Maruti Suzuki.
f) The vehicle must not have been assembled, disassembled, adjusted or repaired by other than authorized
dealer/ service station.
g) The vehicle must not have been used for purpose other than what it was designed.
h) Any defects caused by misuse, negligence, abnormal use, insufficient care, abuse, flooding or fire.
i) Use of improper, adulterated or insufficient or bad fuel, fluids or lubricants.
j) Any damage or deterioration caused by airborne fallout, industrial fallout, acid rain, hail or hail storm, bird
droppings and other Acts of God.
k) Insignificant defects which do not affect the function of the vehicle including without limitation, sound, vibration
and fluid seep etc.
l) Any natural wear & tear including without limitation, aging etc.,
m) Vehicle retrofitted with LPG & CNG kits cannot be covered under extended warranty.
3. List of Components not covered:
This is limited list of items not covered:-
a) Normal maintenance service required, including without limitation, oil and fluid changes headlight aiming,
fastener retightening, wheel balancing, wheel alignment and tyre rotation, cleaning of injectors, ignition timing,
clutch and valve clearance.
b) The replacement of normal wear parts, including without limitation, bulbs, headlamp assy including projector
headlamp / tail lamp / fog lamp assembly, battery, tyres, tubes, spark plugs, brake discs, brake shoes, brake
pads. Internal parts of brake master cylinder & wheel cylinder, belts, hoses, filters (air / fuel/ oil / AC) with or
without sensors, wiper arms/ wiper blades and brushes.
c) Any seals and Gasket replaced or refitted as part of normal-schedules.
d) Clutch disc, clutch pressure plate, clutch release bearing, radiator, catalytic converter, muffler, AC gas leakages
and differential backlash under any circumstances.
e) Replacement of timing belts as per recommended interval.
f) Trims, wheel rim, wheel alloys, rubber & plastic parts, glass machine, all body parts including door regulators, glass run, seat fabrics, roof lining, gear knob, steering wheel logo, all emblems, cup holder, door weather strips
etc.
g) Smartphone Linkage Display Audio (SLDA) unit
h) Any repair or replacement required as a result of accident or collision, misuse, abuse, theft, flooding or fire.
i) Paintwork, bodywork and mouldings, water entry into the vehicle, corrosion of body parts, glass, Mirrors (inner
& outer), lock cylinder & key & interior trims.
j) Humming noise in any component.Note: Maruti Suzuki reserves the right, at its discretion to change, modify, add or remove portions of these terms at
its sole discretion at any time. Please check these terms periodically for changes.
4. Disclaimer of Consequential Damage :
Maruti Suzuki assumes no responsibility for loss of vehicle, loss of time, inconvenience or any other indirect
incidental or consequential damage resulting from the vehicle not being available to the owner because of any
defect covered by this extended warranty.
5. How to make a claim:
In the event of the occurrence of the breakdown the owner must:
1. Immediately take all steps necessary to minimize the extent of loss.
2. Depending on whether the vehicle is in a condition enabling it to be driven, the owner shall drive it or have it
towed, without delay, to the nearest Maruti Suzuki Dealer at his own cost to effect repair according to the
dealer/ Maruti Suzuki’s requirements and to notify the dealer of this warranty contract number.
3. Authorized the dealer to establish the cause of breakdown.
4. Undertake to pay the cost of dismantling and repairing the vehicle if the cause of the breakdown is not covered
by this warranty. The owner is responsible for paying for any other work that the owner asks the repairer to
carry out.
5. The service record and service bills must be made available to the workshop personnel.
6. Owners warranty responsibility:
a) The vehicle must have been serviced as per guidelines in the service manual from authorized dealer/ Maruti
Suzuki authorized service station.
b) Make certain the extended warranty registration was completed at the time of applying for extended warranty.
c) Make certain that the Maruti Suzuki authorized dealer/ service station performing the service inspection has
certified the work on the “Maintenance Service Record” page in the Maruti Suzuki Owner’s manual and Service
Booklet”
d) Present the Maruti Suzuki Owner’s Manual and Service Booklet” to the authorized Maruti Suzuki dealer
whenever requesting service inspections or warranty service.
e) If the “Owner’s Manual and Service Booklet” should be lost or destroyed, the owner should consult the
authorized Maruti Suzuki dealer from whom the vehicle was purchased for instruction concerning replacement
of the “Owner’s manual and the Service Booklet”.
Failure to comply with these formalities and conditions may lead to a refusal to accept the claim.
7. Cancellation of EW Policy
a) Any Extended Warranty if required to be cancelled, can be done till the vehicle is under primary warranty by
Extended Warranty selling dealer. There will be an administrative fees of Rs 200/- or 10% of Extended
Warranty basic price (whichever is higher) for policy cancellation. Also, tax amount collected during Extended
Warranty will not be refunded.
b) Any converted policy (Gold to Platinum, Royal Platinum or Platinum to Royal Platinum) will not be cancelled
| Parts which MSIL mentions are high value and stand a chance of replacement under EW:
-Compressor- Rs 10,000 in aftermarket, Rs. 13k in MGP
-ECM- Rs. 7,000
-Steering Assembly: Column: Rs.36k, Steering Box Rs. 8.6k(this is wear-tear part)
-Suspension: Total cost front and back is Rs. 14k
-Starter motor-Rs. 6k What if I cancel EW today: I'd paid Rs. 17.7k, out of that 15k was base price of EW while Rs. 2700 was Tax. Tax is non refundable while 10% is deduction penalty. Thus I'll get refund of Rs. 13.5k. In addition to this, if I stop going to any MASS or Dealer for service, it all becomes DIY, thus even in the left 3 year period, I stand to save 15-16k rupees(purely on labour). Thus if I go that way, I straightaway save ~30k rupees, which can be used to replace the component which may fail in the 5 year period. My intention: I have a full fledged house workshop with all tools and supplies including jacks. Thus avoiding dealership will not affect me in any negative way. I'll be free to maintain my car upto my standard. For major repairs, I'll be free to go to my old trusted MASS. What took me 1.5 years to decide on this-Since I had already purchased the EW, I had 2 years to think about it and also get to know the car inside out. Thus with 2 year mark coming in July, I have to make a decision soon.
Given the terms and condition, Maruti clearly escapes defects in expensive components like HL, TL, Power Window, Head unit etc. What's left is not that expensive that it will hurt me in some major way even if they don't cover under warranty. Secondly, I don't see them all failing together by 60k on the odo. Given the cars running today since 2018(Ertiga/Ciaz), components are largely reliable and don't fail by the odo reading I'm eyeing. Peace of Mind: Well not absolutely. We already have a thread running on poor workmanship by a Maruti dealer. In past, my cars including 800 has seen problems arising due to inexperienced dealership staff working on my car. I become tensed whenever time comes for me to avail service from their dealer workshop. Mechanics may be good but I'm not in a mood to experiment everytime. Also the hard reality in these MASS manufacturer's workshops is that most mechanics are there only for gaining experience, once they fulfill their aim, they often open their own small workshops! It is not a well paying job, and any decent mechanic can earn way higher if he services just 1 car per day on his own outside. Do the maths! Thus ruining my car slowly with hope that Maruti will cover some part someday, doesn't work for me.
Just to give you an example, during ISG replacement, I saw the mechanic trying to open a bolt, at an angle using his impact gun and rigid extensions! A sure shot way of ruining the bolt I'd say. I requested him to use a universal flexible joint in between, but his ego got in the way. After few failed attempts with the rigid extension, he finally used the universal joint and out came the bolt in first attempt! He was quite miffed after that and another old mechanic carried the job ahead, thankfully! So not everything is fine with workshops.
What's your opinion on this, am I missing something? I mean XL6 MT is neither a complex automatic, nor has a turbo petrol or diesel engine. It is neither a premium German with expensive parts or from a manufacturer known to have frequent niggles. After knowing Maruti's service since years, and given their weird terms and conditions for EW, I'm feeling like the money will go down the drain without me using anything.
Shashi
