Frankly the best and most affordable option of transporting your bicycle is via the Indian Railways (IR). They are
- Efficient
- Reliable
- Affordable (extremely!)
I have taken my cycle on numerous journeys
1. Mumbai to Chennai
2. Goa to Bangalore
3. Kanyakumari to Chennai
4. Chennai to Bangalore
5. Bangalore to Mangalore
and a few more. The process more or less remains the same with only a few minor differences; however the experience has been pretty much great across all my previous trips using the railways. I have faced zero damage to the cycle on any of these trips. I would whole-heartedly recommend this option to all cyclists for their cycles at any price point.
Let me explain the process in more detail
Step 1: Select the mode of transport. There are two options that IR offers us - luggage and parcel
Luggage - The cycle can be booked as luggage if you are travelling by the same train
Parcel - the cycle is booked as parcel if you are not traveling by train along with the vehicle
A few additional details to remember
- 'Luggage' gets priority over 'Parcel'. Basically if you are traveling on the train, your goods have to be on
that train itself. Everything else comes next
- 'Luggage' option is possible only on select scenarios; at the starting & ending stations; and at a few key / important stations that your train will stop for longer duration. As a thumb rule, avoid any train that have <5 mins halt time at your start or destination station
- For the 'Parcel' option, it's up to a combination of what train is best suited to deliver the goods/cycle to the destination station and depends on a variety of other factors (
other goods being transported that day, # of trains running on that route, direct connectivity, etc.)
- Fees/charges are more or less similar for both options so it doesn't matter
- Of course if you aren't traveling, then parcel is your only option
- For any doubts, head to the luggage counter of your station or call 139
Note: I have sent my scooter via the parcel option. The vehicle reached the destination 2 days later than planned even though we were told at the source point that it would be sent the same day itself. But no other issue faced other than that.
Step 2: Select the train that you want to take your cycle with you. As a thumb rule, I look for trains that originate from my source station and end at my destination station for transporting my cycle; even if I have to overlook better/faster train options. Every train has two luggage vans; one van is usually reserved for goods from starting city to destination city and the other van is reserved for goods for all other combinations. The former luggage van door is locked/sealed at the source station and only opened at the destination so obviously it makes more sense to get your cycle in that van.
Step 3: Reach the luggage counter on the day of journey at least 4 hours in advance. Reach the day earlier if your train timing is at odd hours (
e.g. early morning). I once reached ~2.5 hours prior to my evening train; and I was told that it might be tough to get a slot on the same train even though I was traveling on it. Luckily there weren't too many goods so no constraints faced.
The luggage counter is not necessarily at the parcel office (
in some cities it can be). In Chennai & Mumbai, the luggage counter is inside the station near the main entrance & away from the parcel office; while at Bangalore & Goa, it is located separately outside the station as a separate building/unit adjacent to the parcel office. Ask around and you'll be shown to the correct premises.
Step 4: The official at the counter would require that your cycle has some packaging. Basically they need some covering on which they can write down the parcel number or put the tag/sticker. At most stations, you'll have guys loitering around who'll offer to do the necessary packaging for a nominal charge. Or you can carry the packaging material and do it yourself. I have paid different amounts from 50Rs to max 200Rs for this "service".
Step 5: Fill up the luggage form with the key details including your ticket PNR. If you don't have a PNR, then the same form acts as a parcel form. You will also require a xerox of your ID (DL/Aadhaar/etc.) for this process. The official will book the details on the parcel system and give you a receipt. At some places this is computerized, while at other places it is manually recorded (
e.g. Kanyakumari). For main stations like Chennai or Bangalore, I got a printed tag/sticker that I could stick on the cycle along with the receipt. Do not lose this receipt - it's key. Especially the PRR No. / PWB No. on your receipt is important as it allows you to track the transport status online on Indian Railways site
https://parcel.indianrail.gov.in/
Sample receipt for reference Step 6: The next steps varies from city to city but in general, there'll be a counter/location where all vehicles that need to be transported (
usually close to the luggage counter or on platform #1) - your cycle gets deposited there and your work is done. There would be a porter who'll keep track of all vehicles that need to be sent out as luggage/parcel and it's his job from there. Atleast, that is the process officially. At some places, I have been asked to pay a nominal charge (
e.g. recently at Kanyakumari a 100Rs charge), others I just walk away and come back when the train arrives.
Step 7: This is an optional step. If your train is starting from that station, you can choose to be there an hour earlier when it arrives at the station and observe the porter(s) load your cycle on to the luggage van. As a thumb rule, I always try to be there to ensure the cycle is loaded correctly - once my cycle was to be loaded on top of a lot of goods/crates as the luggage van was filled to the brim. I ensured the derailleur and other components would not get impacted and there is sufficient cushion.
It's always good to see your cycle loaded in front of you
Of course, if you are opting for parcel service, there isn't anything you can do here as there isn't a guarantee on which train your cycle will be loaded. In the past, one had to bribe the porter to ensure the vehicle is loaded asap - but these days, the system is quite efficient and you can expect your vehicle/cycle to be sent asap. You can still choose to do that if you think it'll help.
Step 8: At your destination, get down and head to the parcel office (
NOT the luggage counter) as all goods from the luggage vans will be sent there. Many a times, I have walked with the porter carrying the goods to the parcel office. You can also choose to come back later to pick it up at the parcel office. Show your receipt at the counter and he'll check for any pending fees (
there are penalty fees if your cycle/vehicle has been at the parcel office more than the initial 6 hours). Once all aspects are cleared, he'll sign the form (
or give you a delivery token or receipt) and you are good to go.
Rules / fees at delivery point Additional Points to note
1) The IR transport charges for your 10-12kg cycle will be extremely nominal (
max I have been charged is 200Rs). The IR can "earn" a lot more with goods using the same space your cycle takes but they offer this amazing service so I would advise IR option over any other means of transport any day
2) In a city with multiple stations, this service could be offered at more than one station. For instance, both Bangalore SBC and Yeshwantpur offer this service.
3) Most porters/railway staff would be unaware of the cost of our cycles but they are definitely aware of cycles and are generally lenient/helpful (
maybe fellow cyclists?) so some smiles (
and token payment if requested) do help where needed
4) If your travel originated from a station with computerized terminal, you'll get sms alerts of your cycle/vehicle being loaded, unloaded and so on
5) The same alerts can also be tracked on the IR parcel website (
for both luggage & parcel options)
