The Unholy Conversion | Road Bike to TT Bike Just went ahead and did the unthinkable !
Converted my Road Bike into TT Bike.
I know many purists wont take this idea, however i wanted to have a unique proposition that will turn heads. Also, guess i found my calling in Time Trials. Choices:
I am fortunate to own to beautiful Aero bikes. The Merida Reacto 400 is an alloy frame with Carbon Forks and Seat posts, whereas the Look 795 Blade RS is an all carbon frame. The Merida is more humble yet immensely capable machine. The Look is newer, more flamboyant head turner. The Merida
I initially wanted to convert the Merida to a TT setup, however, it made sense to
use a lighter bike for TT since it has a single specific goal. Besides, that the Merida also has a slightly older and lower down the performance chain - 105 groupset. Components: I wanted to do a proper TT conversion and not just fitting an aerobar on a roadie handlebar. This involved quite bit of proactive thinking including Bike fit related aspects as well as specific components to match the existing components. I decided to keep the weight down and hence went for all Carbon components. Also, i shied away from integrated cockpits since i wanted flexibility over aesthetics. What went out:- Look ADH2 Road Bike Handlebar
- DuraAce Integrated Shift cum brake levers
- Existing wiring
- Existing Bartapes
What went in:- Profile Design Svet-R basebar
- Profile Design Ergo 35c Aerobar
- Profile Design Bar Riser - 70 mm
- Profile Design Carbon TT Brake levers
- DuraAce 11speed TT Shifter
- New wiring
- New Aero Bartape
Modifications in existing fit: The change required extensive modification to the existing fit and appearance of the bike.
Removed all Spacers, Cut the steerer tube to Flush fit the base bar
Additional Aerobar extensions cut after Bike fit
Seat Post mount reversed and Seat mounted farther up for better reach
Complete Bike fit for TT position. Some weight indices (with Pedals and Mounts)- Merida Reacto 400 - 10.2 kgs
- Look 795 RS (Road bike fit) - 8.4 Kgs
- Look 795 RS (TT fit) - 8.8 kgs
Will let the pictures do the talking
