Old 22nd November 2010, 21:16   #61
Thanked: 11 Times
@sashas:
Is the oil pump in the front or rear? Just wondering how you handled the oil pump when you modified the sump..
The oil pump is in the rear side.
sashas is offline
Old 22nd November 2010, 22:02   #62
Thanked: 110 Times
some months back i had raised this question in this forum,but no one replied,now am happy that similar idea had poped up in someones mind.
Qualis engined MM550 ! super engine with super off roader
BTW can you add turbo to qualis engine? and can innova engine be transplanted into jeeps?
joshguy is offline
Old 22nd November 2010, 22:11   #63
Thanked: 11 Times
No idea about turbo in qualis engine,innova engine can be transplanted into jeeps but the major problem will be wiring.
sashas is offline
Old 23rd November 2010, 10:20   #64
4x4addict's Avatar
Thanked: 4,648 Times
Infractions: 0/1 (5)
Changing a stock XD3P engine with a qualis engine will not improve the off-roadability of the MM550XD in anyway. The only advantage is that engine along with the BA10 will make it a lot more refined.
4x4addict is offline
Old 26th November 2010, 21:12   #65
Hilux engine on MM540
Hi,sashas. Iam in UK and planning to buy an MM540 either 4wd or 2wd, Would you please get me the contact for your mechanic so I can get some tech advice about engine. In fact iam planning to buy a Toyota hilux engine and gear box to be mounted on an MM540. Before I spend the money its always better to get some tips,cheers Sobin
johnsobin is offline
Old 27th November 2010, 00:40   #66
Thanked: 704 Times
Originally Posted by johnsobin View Post
In fact i am planning to buy a Toyota hilux engine and gear box to be mounted on an MM540. Before I spend the money its always better to get some tips,cheers Sobin
Not a good idea! Most of the Toyota 4WD have their front drive shaft on the left side!!!
jyobeb is offline
Old 27th November 2010, 00:44   #67
Samurai's Avatar
Thanked: 48,986 Times
This MM540 has Toyota Hilux engine and gearbox.
Samurai is offline
Old 27th November 2010, 01:12   #68
Thanked: 704 Times
Which engine is that?
The R150F transmission had the front output shaft to the left.
jyobeb is offline
Old 27th November 2010, 12:47   #69
Samurai's Avatar
I don't know the exact engine, the Jeep belongs to Shakir Ahmed who is a silent member here I think.
Samurai is offline
Old 27th November 2010, 16:57   #70
Thanked: 704 Times
Should be a G52 gearbox. Good gearbox and should be a right fit. I stand corrected!
jyobeb is offline
Old 27th November 2010, 21:12   #71
Thanked: 727 Times
the routing of snorkel is ludicrous.
Just curious is this engine NA or TC.?
SirAlec is offline
Old 28th November 2010, 16:09   #72
Thanked: 11 Times
The vehicle is back home after a major modification.
sashas is offline
Old 28th November 2010, 17:11   #73
Thanked: 704 Times
Pictures pleas. Sounds like an interesting conversion!
jyobeb is offline
Old 11th December 2010, 20:21   #74
Samurai's Avatar
re: A restored MM550 and how...
Now the Qualis MM550 is undergoing engine run-in. It is able to effortlessly cruise at 110-120 on the NH17. AC is a chiller, engine is almost noiseless. A Warn 8000lb winch just got installed. The winch plate was bent in Mangalore since nobody could do it in our district.
These photos were taken quite late in the evening, sorry about the poor quality and noise.
The winch.
The huge qualis exhaust pipe
Under the hood, the Qualis 2.4L engine.
Air filter from petrol Amby
Fan from Isuzu engine, Radiator from Eicher truck.
The AC blower
The AC switches.
Samurai is offline
Old 13th December 2010, 13:54   #75
IronWolf's Avatar
Thanked: 45 Times
Very nice a clean looking transplant. Thanks for sharing.
Apart from the 18k for the engine, could you share some costs?
This would work only with the BA10 GB? Would not be possible with the T18 box?
No plans or rerouting the exhaust or use a smaller silencer chamber? Thats gonna hit during some serious offroading isn't it?
IronWolf is offline
