Old 27th March 2009, 16:17   #106
headers's Avatar
Thanked: 563 Times
Ankit,
I've had no problems even with 215/75s Pirelli Scorpion on Loose sand..
It is better that all the 4 tyres have the same OD..
headers is offline
Old 27th March 2009, 16:23   #107
nitrous's Avatar
Thanked: 332 Times
It isn't better!
It is absolutely mandatory to have the same OD at all four corners in a 4x4.
nitrous is offline
Old 27th March 2009, 16:26   #108
headers's Avatar
Thanked: 563 Times
Originally Posted by nitrous View Post
It isn't better!
The BOSS is ALWAYS RIGHT..
headers is offline
Old 21st June 2009, 16:45   #109
praveencr85's Avatar
A quick question to all ...
can we retain the 4x4 if we get a swift's DDIS engine into gypsy?
I am saving all my money to get my dream offroader...kindly help.
praveencr85 is offline
Old 21st June 2009, 17:33   #110
4x4addict's Avatar
Thanked: 4,648 Times
Infractions: 0/1 (5)
I am no expert on the Gypsy. However from reading various gypsy mod threads people have been able to retain 4WD after other conversions, so it should be possible. The only tricky part would be that the DDIS is a side mounted engine, whereas he gypsy has the engine straight so I am not sure if this causes any additional issues.
4x4addict is offline
Old 22nd June 2009, 06:23   #111
headers's Avatar
Thanked: 563 Times
A transverse engine can be mounted normally. The trick is in mating the engine to the gearbox! I too am searching for a DDIS first, and a donor gypsy next!
headers is offline
Old 22nd June 2009, 16:50   #112
GoSlow's Avatar
Thanked: 78 Times
Looks like we are all dreaming of the DDis Gypsy. I am going to start looking out for this engine next year. Plan is to swap it for the Nissan in my Gypsy currently. Not sure what will hapen when you are using engine braking to go down hill and the turbo kicks in!
Praveen - you can retain the 4x4 because Gypsy has a divorced trnasfer case. The problem may arise with the front diff hitting the sump but then you can get the sump modified to a similar shape as that on the Gypsy King. Though you may want to retain the Gypsy King gearbox as it works well with the transfer case gearing.
Ankit
GoSlow is offline
Old 22nd June 2009, 17:57   #113
Shubhendra's Avatar
Thanked: 2,332 Times
Hi Ankit,
If I am not wrong you work in Sector-127 Noida. i have seen your Gypsy few months back probably after accident when you was driving damaged vehicle. I am with HCL Technologies (Sector 126)Actually i Have the same Nissan engine in my Jeep and i want to overhaul this engine as i have used it for almost 4 years(Don't know the Kilometers. Can you please PM me address of Mechanic who has done this conversion.
Shubhendra is offline
Old 22nd June 2009, 18:07   #114
Thanks for the input guys ..
I ill be back in india by december, so by that time i need to acquire this DDIS engine. frns are helping me in searching the same . can i get a new engine from maruti directly?i dont mind spending money for a brand new engine as it ill be a life long affair with gypsy(my first luv) .
Old 22nd June 2009, 20:27   #115
headers's Avatar
Thanked: 563 Times
Ankit, Hi, Nothing will happen when going downhill. Infact Turbo will not kick in unless one accelarates!
headers is offline
Old 23rd June 2009, 09:26   #116
GoSlow's Avatar
Thanked: 78 Times
I did contact Maruti for this conversion and they wrote back telling me to Contact one of the dealers/workshops and they will be able to do this for me. I did not take it further at that point.
Ankit
GoSlow is offline
Old 24th June 2009, 09:54   #117
GoSlow's Avatar
Thanked: 78 Times
Sounds good. Its all ahead then... well after recession that is.
I am changing my tryes for the stock Gypsy tyres. Getting some brand new ones donated to me by one of the NIOC guys (The guy in the pic who is driving my gypsy) who bought a brand new Gypsy and is getting 35" tyres fitted to it with coil spring suspension.
Its the rear tyre which lets me down each time and cant afford to buy new tyres right now. What do you guys think?
GoSlow is offline
Old 24th June 2009, 10:14   #118
renegade's Avatar
Thanked: 43 Times
good going goslow, you got a very nice gypsy,had a good ride in it while coming back from an otr in hisar,though the credit of a good ride goes to our "chadha saab" as he didnt let us feel the bumps as he flying over them.I have been having a weird idea on engine conversions and i am usually not practical in this field,i would like to know,how about plonking in a d4d(innova diesel) with adapter plate for the gearbox in a gypsy?just a thought.
ciao
mandeep
renegade is offline
Old 24th June 2009, 11:36   #119
harjeev's Avatar
Thanked: 296 Times
@Mandeep
Thanks buddy!!! The pleasure is all mine
You can have that ride anytime you want!!! I will happily play driver for you!!!
The Innova experiment should be great!!! When are you trying it out. What would be the options of the Innova engine vs the DDiS MAruti Swift engine!!!
What's say Ankit!!! Whenever you think of changing the engine this should be a good option. I perso
harjeev is offline
Old 24th June 2009, 13:08   #120
GoSlow's Avatar
Thanked: 78 Times
Hi Mandeep/ Harjeev
Toyota D4D is quite a powerful engine. Good thought!
How much does it weigh? Will there be issues with the front being too heavy and compared to the rear of the vehicle? I would like to see this done. would make it a MONSTER offroader!
Ankit
GoSlow is offline
