Old 13th October 2008, 18:21   #16
NDMS in 7.50/16
Dear Headers,
great to know that you have used a NDMS with 7.50/16, are you sure of the size, as 7.50/16 are not available in the market,
Is it possible for you to take a closer picture of the same, with details of the manufacturer,
Sorry to jump in, My name is Vinay Thomas, I have a few CJ3B in my collection, Quite a few form the this forum know me & vice versa,
till then take care & best regards
Vinay thomas
Originally Posted by headers View Post
Hi guys,
My used '89 MM540 DP 4x4 came with some junk roadside tyres. The first step was to change the tyres as the footprint was important to me.
Got a set of 7.50 x 16 NDMS for my jeep. As I've heard from fellow jeepers that the 7.50 x 16 is great in any environment for the jeep.
Attachment 58642
Then started using the jeep for my factory use, which included a weekly run of almost 300 kms on pure tarmac road. The road presence of a jeep is superb with everyone and anyone giving way on the road. A load of 2 barrels filled with Diesel / oil made the jeep suspension soak up bumps like a car.
The major drawback came in from braking. Though it would not do speeds in excess of 60 kmph [self imposed limit], when an idiot runs across the road, it becomes imperitive to brake hard and the jeep / tyres fail to do justice to that situation.
Hence
Attachment 58643
This is my jeep with my used 215/75 R15 Pirelli Scorpion tyres on gypsy rims. This was just an experimental setup to explore the braking and handling of the jeep especially on tarmac.
Observations of the new avatar on my jeep. Take off and accelaration were better as the effective OD was smaller than the pervious setup. In gear accelaration was also brisk and made the jeep enjoyable to drive on the road.
The downside came in the form of a very hard steering. [These tyres were also excessively worn out and not uniform]
But braking had improved considerably and surprisingly the body roll increased too with broader tyres.
Drove the jeep in this guise for 2 weeks before changing back to NDMS setup.
Just thought of sharing this information with TBHP!
CJ3b is offline
Old 13th October 2008, 20:18   #17
im_srini's Avatar
Thanked: 490 Times
All F1 cars have positive camber.
Hi Headers, I think you meant negative camber. F1 cars typically have noticeable negative camber on the front & little or no negative camber on the rear.
Postive camber can be seen on the inside wheels of NASCAR cars that run on oval tracks.
im_srini is offline
Old 13th October 2008, 23:09   #18
Samurai's Avatar
Thanked: 46,689 Times
Originally Posted by nitrous View Post
Here's the thing about rim offset.
Positive offset would "narrow down" your track.
Negative offset would "widen" your track.
It is NOT the other way round.
Exactly, I was wondering why BT was implying the reverse. I am actually thinking of switching to negative offset wheels to improve the track, but I want to understand all the cons before that.
BTW, Welcome to Team-BHP Vinay, it was high time.
Samurai is offline
Old 14th October 2008, 02:43   #19
DirtyDan's Avatar
Thanked: 1,598 Times
I wish somebody who knew something about it (I do not) would start a thread specifically on handling to include offset, the addition of power steering to jeeps and such like.
DirtyDan is offline
Old 14th October 2008, 02:49   #20
iraghava's Avatar
Thanked: 272 Times
Let me clarify a small point, if you look at the tread patterns on the NDMS tyre & compare it to the radial, you can immediately see that the contact patch of the radial is much better then the NDMS tyre. This would lead to better grip & performance in on-road conditions.
Whereas, the NDMS would perform better than the Radial tyre in off-road conditions.
Both the tyres are designed for different purposes & would perform to the best of their abilities in their respective conditions. Just my two cents.
iraghava is offline
Old 14th October 2008, 12:09   #21
Spitfire's Avatar
Thanked: 777 Times
I was looking at negative offset along with spacers for the Classic, dropped the plan after i thought i might be straning the suspension on offroad conditions.
PS: Should we have a separate topic for this. Would be interesting.
Spitfire is offline
Old 14th October 2008, 13:27   #22
Blue Thunder's Avatar
Thanked: 396 Times
Correction !
nitrous, thanks for correcting it : you are right . I guess I misunderstood the usage of the terms "positive" and "negative" when referring to the offset. I stand corrected.
The standard Gypsy rim has a more negative offset compared to the standard MM540 wheel rim.
But, what I said below holds good anyway
Originally Posted by Blue Thunder View Post
...When we replace the MM540 wheel rims with those of a Gypsy, we are in fact increasing the front track width.
Blue Thunder is offline
