Closed Thread
Old 11th April 2008, 11:31   #151
4x4addict's Avatar
Thanked: 4,648 Times
Originally Posted by nitrous View Post
^^Switch to dry type air filter from the oil bath type. We've noticed good power gains in Arka's jeep.
My MM540 (2002 model) came with the Dry type. So I will just keep the same unit with the XD3P engine.
4x4addict is offline
Old 11th April 2008, 12:47   #152
headers's Avatar
Thanked: 563 Times
Unless the 540 had modifications or a bigger engine, I dont see why. Logically, the lighter weight and smaller dimensions of the Classic (wheelbase etc.) would make it a better performer off the road.
You forgot the wheelbase and weight factor GTO..
Originally Posted by DirtyDan View Post
The Classic is really a terrible, terrible off-roading piece of junk.
Well..thats if :
1. You dont KNOW how to HANDLE JEEPS
2. Have not done Offroad in a Jeep
3. Have done offroad in one of those new sissy vehicles and have the "moolah" to do the offroad in comfort.
Classics are awesome machinery..but need to be maintained well to take the best out of them.
If I were GTO, I would not have stopped with an infraction: LOL
DirtyDan : My Jeep is NOT for sale . You ought to get an infraction for personally attacking my Jeep like that.
I dont presume the Major comes with free wheeling hubs as stock fitment. You could add them after-market though.
You dont need freewheeling hubs IMO. Its better as incase we want to try a terrain in 2WD mode, get stuck, then you'll be forced to get down to do the works!
Guess which engine is currently being shoehorned into my Classic? Yup, the same XD3P 2.5 liter 72.5 horse unit.
Yeah, we are all eagerly awaiting your report! When is it gonna be ready?
Originally Posted by susan3004 View Post
Major does not have a free wheeling hub.
Thats great news..way to go..maybe i too should look for one..going by your posts.
Each has its own advantages..Oil bath filter is better in very dusty conditions as well as in areas where deep fording is necessary.
To each his own!
headers is offline
Old 12th April 2008, 12:19   #153
svsantosh's Avatar
Thanked: 8,044 Times
Gurus, please explain this
all 4WD/AWD on one page - a simple, easy to understand overview - all available 4WD, all wheel drive and 4x4 systems and their differences - 4WD concepts, their function, their layout, their purpose, their advantages
I got this from the thread 'lamba free wheeling hubs'.
Now is this Mahindra Major a fulltime 4WD or a part time.
Also what is the Gypsy, or the safari 2.2 4x4, Scorpio 4x4 electric, bolero LX 4x4, bolero SX electric 4x4, mahindra rakshak, mahindra axe, Force Gurkha?, etc etc available in India.
svsantosh is offline
Old 12th April 2008, 13:34   #154
Samurai's Avatar
Thanked: 49,637 Times
This is a total off-topic subject, please start a new thread for detailed discussion. To be quick, I think in India GV is the only full-time 4x4, CR-V and Tucson have auto-4x4, and rest are all part-time 4x4.
Samurai is offline
Old 16th April 2008, 13:08   #155
svsantosh's Avatar
Success at last - Got Info from Mahindra Sales Dept
Guys Please read the chain, It ends with the complete "TECHNICAL" details of the Major 4X4. I just spoke to PADMARAJ JAIN - 9845694939 from Bangalore India Garage, Learnt that Major 4x4 costs 5.17.Rs OTR in bangalore. Also learnt that Invader 4X4 is 6.17 OTR and currently has a 50K offer for the month of April from Mahindra company.
Warranty - Major 4x4 - 3 Years UNLIMITED Mileage (Sounds reassuring)
Engine Specifications -
Engine
MDI 3200 TC Direct Injection Diesel
Type
4-Stroke, 4 Cylinder, Inline
Bore/Stroke
88.9 mm / 101.6 mm
Cubic Capacity
2523 cc
Maximum Horse Power
63 HP @ 3200 RPM (IS)
Maximum Torque
18 kgm @ 1500 RPM (IS)
Fuel Injection System
Inline Pump
Compression Ratio
18 : 1
Weight of Engine
260 kg
General Specifications -
Cooling System
Belt driven pump on cylinder head.
Thermostat controlled.
Clutch Type
Single dry plate, outside dia. 235 mm.
Transmission
Type: 5 Speed,
Transfer Case
2 speed gear reduction, single shift lever
Gear ratio : High 1:1 ; Low 2.46 : 1
Front Axle
Full floating for 4WD only.
Dead tubular for 2WD
Max. Capacity : 907 kg
Ratio : 3.73 : 1
Rear Axle
Semi floating hypoid type.
Max. Capacity : 1134 kg
Ratio : 3.73 : 1
Steering
Worm and Roller type or recirculating ball type
Ratio : 20 : 1
Turning Circle Radius
5.86 m.
Brakes
Type : Hydraulic with TMC
Parking : Operates on rear service brakes.
Hand lever & cable type
Suspension
Front & Rear : Semi-elliptical leaf springs with hydraulic double acting telescopic shock absorbers
Wheels
Rim size: 16 x 4.5 in. Disc type, with five studs.
Tyres : 6.00 x 16, 8 PR
Frame
Ladder type with steel channel side members, four intermediate cross-members.
Electrical System
Battery :12 V / 75 Amps .hr.
Alternator 43 Amps.
Instruments
Speedometer (kms./ hr.), temperature and fuel gauge. Light indicators for battery charging, oil pressure, high beam and flasher. Hazard warning switch.
Fuel Tank
Capacity : 45 litres with electrical float unit .
Kerb Weight
CL 500 - Soft Top 2WD : 1225 kg. 4WD : 1300 kg.
CL 550 - Soft Top 2WD : 1235 kg. 4WD : 1310 kg.
Gross Vehicle Weight
CL 500 : 1770 kg. / CL 550 : 1950 kg.
________________________________________
Sent: Wednesday, April 16, 2008 11:29 AM
To: Sv, Santosh (GE Infra, Aviation, Non-GE)
Subject: Re: Mahindra Major Enquiry
Mahindra CL 550
Engine Specifications -----SEE ABOVE----
for india garage
PADMARAJ JAIN
9845694939
----- Original Message -----
To: -----@ge.com
Cc: mrimdad.khan@gmail.com ; indiagarage@airtelbroadband.in
Sent: Tuesday, April 15, 2008 3:40 PM
Subject: FW: Mahindra Major Enquiry
Hi Mr Santosh
Kindly give your contact no or address our consultant from india garage will come and give you the details of vehicle with price details.
Or you can call mr yatish 9900215207 he is consultant at india garage and will furnish the required details.
Warm Regards,
K.Prashant
Manager-Sales
Bangalore-AO
Sent: Tuesday, April 15, 2008 3:22 PM
To: K PRASHANT
Prashant – get in touch with this customer
Sent: Tuesday, April 15, 2008 11:06 AM
To: BHANU PRAKASH
Dear Bhanu,
Can someone in your office contact this customer?
Warm regards,
Kausalya Nandakumar | Brand Manager - Automotive Sector | Mahindra & Mahindra Ltd | 022 24905857 (Extension Line) | 022 24905773 (Board Line)
www.mahindrasmallcv.com - Partners in Progress
From: Sv, Santosh (GE Infra, Aviation, Non-GE) [mailto:------@ge.com]
Sent: Wednesday, April 09, 2008 1:18 PM
To: SREENIVASAN KAUSALYA
Cc: CUSTOMERCARE
Subject: Mahindra Major Enquiry
Hello Sreenivasan Kausalya and Mahindra Family,
I am interested to buy a Mahindra Major 4X4 and I do not see any technical details of that jeep. Can you please share with me a brochure or the technical details of that vehicle? And what is the cost of that vehicle?
Santosh SV
(Bangalore)
---DISCLAIMER---------------------------------------------------------------------------- The contents of this E-mail (including the contents of the enclosure/(s) or attachment/(s) if any) are privileged and confidential material of Mahindra and Mahindra Limited (M&M) and should not be disclosed to, used by or copied in any manner by anyone other than the intended addressee/(s). If this E-mail (including the enclosure/(s) or attachment/(s) if any ) has been received in error, please advise the sender immediately and delete it from your system. The views expressed in this E-mail message (including the enclosure/(s) or attachment/(s) if any) are those of the individual sender. ------------------------------------------------------------------------------------------
Old 16th April 2008, 14:08   #156
Samurai's Avatar
Maximum Torque
Now that is sweet, music to the ears.
Suspension
Is this different from before, I mean the telescopic shocks?
They are still refering to it as CL500/CL550, I think Major is the marketing name. Please somebody tell me the difference between CL500 and CL550.
Samurai is offline
Old 16th April 2008, 14:32   #157
svsantosh's Avatar
samurai, does this help
http://www.team-bhp.com/forum/indian...tml#post337415
(just noticed you have commented in the same thread, so you may already know of this post, "IF" my memory serves me right, the difference between 500 and 550 is got to do something with ONE engine or Wheelbase parameter. Not able to recollect it, )
Other gurus, plz help..
Old 16th April 2008, 16:13   #158
Thanked: 57 Times
@svsantosh the prices mentioned by include the discount ????
dinar is offline
Old 16th April 2008, 16:59   #159
svsantosh's Avatar
let me clarify, Major 4x4 - 5.17 OTR,(Invader 4x4 6.17 OTR - April Dicsount 50K = 5.67 OTR Bangalore), hope that helps
Old 16th April 2008, 17:11   #160
simply_sunny001's Avatar
Thanked: 19 Times
discount only on Invader ? ? not on Major ?
simply_sunny001 is offline
Old 16th April 2008, 19:23   #161
headers's Avatar
Thanked: 563 Times
Yeah..but the international engine is HEAVY man..and not too great for offroad..
headers is offline
Old 16th April 2008, 19:48   #162
Thanked: 19 Times
but nobody is going to buy a new jeep only for purely Off road,
Old 17th April 2008, 09:18   #163
svsantosh's Avatar
sales rule - discount low demand products. Never on higg demand products. If you stay anywhere near western ghats, andra, or the beautiful himalaya;s you may notice how much the major and CL650 (Longer WB for upto 10 people) sell Like HOT CAKES. So sorry sunny, no discounts for people like us on Major
Old 17th April 2008, 11:29   #164
headers's Avatar
Thanked: 563 Times
Sandeep, Hi,
Yeah, agreed, I was just stating that the international engine is not as refined as the Peugeot Engine and also has a very short powerband. There is amazing low end torque and the clever gearing makes driving one easy.
The real problem is faced only in some tough situations when you feel that the engine does not have juice.
But having said that, i agree that very very few jeeps [majors] are going to see such situations.
headers is offline
Old 17th April 2008, 12:03   #165
Samurai's Avatar
That probably explains why Invader comes with Peugeot XD-3P H IDI engine. No turbo lag to deal with.
Samurai is offline
Closed Thread
