Old 4th December 2012, 14:51   #76
Thanked: 5,406 Times
Re: MM550 XD NGCS - The War Horse
Originally Posted by Jerrycan View Post
The point is if the concentricity is not maintained, you will surely get the feed back on the brake pedal.
But unless some metal is removed, the first oversized liners will not fit in.
This is a routine followed by all the local workshops. There are atleast 3 workshops(lathewallas) in Coimbatore who are dedicated to automobile part conditioning for more than 3 decades. The front propeller shaft on my 550 was missing when I took delivery. I bought a yoke and teeth assembly and a seamless pipe. The lathewalla fabricated the shaft, dynamically balanced it and is now working fine on my jeep.
Dear Jerrycan and all - I am not casting aspersions on anybody's capacity or capability. I have only stated the fact. I have visited umpteen number of "Expert Lathewallahs" so I know how they work. In all my years working with cars and their drum brakes, I have not yet machined the ID of a single brake drum, even when there were a lot of lines on it. Just a brief dab with a sandpaper followed by a thorough wash with a neutral solvent is all that is required.
Take the brake disc. Manufacturing it is not an easy task although the part looks very simple. When we get a field issue, the caliper guy blames the disc guy for concentricity, the disc guy blames the caliper guy for alignment and axial float. It finally becomes very frustrating, going back and forth. Go one step further. Go to motorcycle brake disc. Can you now imagine the process controls required? The caliper is fitted on a moving fork! If this is reality, how can a humble lathewallah exercise so much statistical control? I once again state that I am not casting aspersions on anybody's capacity or capability. I have only stated the fact.
That's why, avoid doing things which need very stringent control, not within the purview of normal operational capability.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks
Old 5th December 2012, 07:47   #77
sreejeshmp's Avatar
Thanked: 887 Times
Dear Sreejeshmp - be prepared for "morning sickness" (sudden grab on gentle application in cold condition and high humidity). Both these symptoms will affect the drive experience of your vehicle negatively. In photograph 1 of the same post, the circlip is required to control the axle shaft end float, please do not remove it.
Please do not do things which are not required to be done. If in doubt, please ask. I am sending you my mobile number by PM.
Best regards,
Behram Dhabhar
Dear Sir,
Yes, I faced this problem in my Old 550 after moving to first over. My rear left side drum got stuck in my old jeep.In that jeep the right side was first over and left side was Standard So I changed the left side to first over and from the very next day first time breaking problem stated I didn't get more time to check that problem as It got sold. But Now only I understand the real reason .Will test the jeep tomorrow morning.
- Sreejesh
sreejeshmp is offline   (1) Thanks
Old 5th December 2012, 11:10   #78
Originally Posted by sreejeshmp View Post
Dear Sir, Yes, I faced this problem in my Old 550 after moving to first over. My rear left side drum got stuck in my old jeep. In that jeep the right side was first over and left side was Standard So I changed the left side to first over and from the very next day first time breaking problem stated I didn't get more time to check that problem as It got sold. But Now only I understand the real reason. Will test the jeep tomorrow morning. - Sreejesh
Dear Sreejeshmp - thank you for understanding and recognizing the root cause of a vehicle issue. Now, like this, you think independently for each and every thing that you do to the vehicle. You will get all the answers yourself. This is plain and simple common sense. As a matter of fact, the complete vehicle from the front bumper to the rear bumper is an extension of common sense only.
Oversize liners become radially thick because the metallic shoe diameter does not change, so their vibration characteristics change completely when they touch the drums. Besides pedal pulsation, you will lose pedal feel and deceleration. Please revert to OE specification.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (2) Thanks
Old 5th December 2012, 21:10   #79
sreejeshmp's Avatar
Thanked: 887 Times
Some WIP pics.
Door setting, I really don't know what they did but opening and closing is perfect .
Shafeer's 550XD Came to see the NGCS , He was on the way to Nilambur.
Ready to Drive for the first time.
Driven to home, tomorrow taking for a 30km Drive to Feroke for Painting.
This will be the color, Thank you Dhanush.
Old 5th December 2012, 21:17   #80
Thanked: 84 Times
This is a nice color sreejesh. Planning for a matt finish rt?
ArunV is offline
Old 6th December 2012, 00:21   #81
commander's Avatar
Thanked: 189 Times
Hi sreejesh. Looks like some unique color. Will definitely come out great with a dark brown and black theme. Hope to catch up soon in Coimbatore.
commander is offline
Old 6th December 2012, 00:35   #82
rajeev k's Avatar
Thanked: 1,954 Times
Moving to first Over size is a normal thing in Kerala, May be all over India and there is nothing juggad on it.
I have visited umpteen number of "Expert Lathewallahs" so I know how they work. In all my years working with cars and their drum brakes, I have not yet machined the ID of a single brake drum, even when there were a lot of lines on it. .
Hope the point is now quite clear. The subject lathe looks every inch a juggad one.
rajeev k is offline
Old 8th December 2012, 08:57   #83
sreejeshmp's Avatar
Thanked: 887 Times
Painting not yet started .
Three things to be done before Bangalore OTR
A simple front bumper
Name:  Screen Shot 20121208 at 7.28.28 AM.png
Skid plate / Guard for Both Diffs.
Skid plate for Leaf Spring U bolts. (I got stuck on the U bolts more than 3-4 times in my Old Jeep)
Name:  Screen Shot 20121208 at 7.28.54 AM.png
Old 11th December 2012, 22:56   #84
sreejeshmp's Avatar
Thanked: 887 Times
Painting started.
Got the spare wheel rim . Thank you V.Prabhu for pointing the right civilian vehicle .
Old 12th December 2012, 11:53   #85
A gift from A jeeper Friend
Attachment 1016381
Will be fixing like the CJ7.
Tinkering started some WIP pics
Attachment 1016382
Attachment 1016383
Attachment 1016384
Attachment 1016385
Hope I can finish the tinkering this week.
Hi Sree, where did you get hold of those Jeep emblems, and how much did it cost. Need for my ride as well.
abhilash is offline
Old 15th December 2012, 22:39   #86
Jerrycan's Avatar
Thanked: 124 Times
Can you Please share the details of "the Right Civilian Vehicle" I need to get some spare wheels too.
How is the paint job coming out ? Do post some WIP picture. What do you have in mind for the canopy ?
Jerrycan is offline
Old 16th December 2012, 18:01   #87
sreejeshmp's Avatar
Thanked: 887 Times
Hi jerrycan,
Which parts you need ? The civilian vehicle is Force Pick-up, for 16" Wheels .
I am getting a Thar CRDe canopy from a friend hope it will be a direct fit.
Painting takes more time than I expected .The painter seems like he is enjoying the work on my Jeep.
made a DIY base model for the custom bumper ,thinking to do it myself .
base for dimensions
imagining the final design .
checking the model
Did it.
I will be using a heavy 16 gage sheet or a 2-3mm sheet.
Old 16th December 2012, 23:13   #88
Jerrycan's Avatar
Thanked: 124 Times
16 SWG or 1.6 mm should be okay. Make them as light as possible. Bumpers should not transfer the impact to the Chassis in case of a Hit. I may be wrong, the gurus can throw some light here
Jerrycan is offline
Old 17th December 2012, 11:53   #89
Thats a nice design, waiting to see the final.
@Sree, can you let me know on that Jeep emblems.
abhilash is offline
Old 17th December 2012, 16:26   #90
sreejeshmp's Avatar
Thanked: 887 Times
Abhilash that Jeep plate is a gift from a friend. It's not for selling purpose, he made it for his jeep and gifted one set to me.
