Old 23rd May 2015, 23:09   #346
ringoism's Avatar
Thanked: 4,478 Times
Re: Tata Sumo four-wheel-drive
Originally Posted by 1100D View Post
The first one, from the fourth picture, seems to not have the front driveshaft (CV joint), probably converted to 2wd, or its the picture quality.
Actually the driveshafts/CV's were all in place (it was only a year-old vehicle and was purchased in 4x4 form because 4x4 is very much needed on the Malana link road) - It was a little dark under there and forgive my not post-processing sufficiently for it;
But I suppose this underscores the fact of extreme similarity with the 2WD version's underpinnings. Wherein, I believe, is also the greatest potential weakness in the IFS setup - Sumo/Spacio chassis rails are very prone to twisting over time when used in continuously rough service, and I could show you pics of many (incl. my father-in-law's!) that are running horrifically positive camber, with all adjustments long since maxed out at the stops. Looks bad, but the tyre wear / evil handling characteristics are even worse. There are ways of straightening the frame rails (hydraulic "porta-power" setups were used in the U.S. back in the day), but nobody up here (or in Mizoram) has the equipment / know-how to do it, AFAIK.
-Eric
ringoism is offline
Old 9th June 2015, 09:02   #347
Thanked: 45 Times
Has anyone tried making a 4wd sumo from a 2wd.
Can a Dana 44 (4.22 or higher) rigid diff's be fitted in front + paired rear, with a Gypsy divorced transfer case.
Or go with a kmt90 and BW transfer case and mate with adapter plate?
Is it practical and do able ?
drsamuelk is offline
Old 9th June 2015, 10:15   #348
Shubhendra's Avatar
Thanked: 2,349 Times
Doable, yes (remember nothing is impossible)
One of t-bhpian has converted bolero 2WD (IFS) to 4WD rigid suspension with dual transfercase, folding shackles, on-demand welding generator etc.. you get the drift ?
Practical - NO. Better buy a 4Wd bolero with manual BW transfercase, plonk CRDe or MHawk engine and you are good for highway as well as serious offroading (a bolero can do everything and may be more that what a Thar CRde can do that - practical experience, no google knowledge).
Shubhendra Singh
Shubhendra is offline   (1) Thanks
Old 9th June 2015, 20:48   #349
Thanked: 6,233 Times
Aside from anything else, torque ratings?
Sutripta
Sutripta is offline
Old 10th June 2015, 11:43   #350
4x4addict's Avatar
Thanked: 4,648 Times
Agree with Shubhendra, In theory anything is possible, but no one has done it so far for sumo, so your vehicle will be an r&d test bed in terms of reliablity.
4x4addict is offline
Old 21st June 2015, 22:17   #351
FourWheelDrift's Avatar
Thanked: 568 Times
Hello all,
Can someone tell me if TATA continues to manufacture the below mentioned vehicle ? If so, which dealer will accept a booking ?
I could find this information at www.mpallonjigroup.com/psterling/content/sumo4x4.htm
Cheers,
FourWheelDrift
SPECIFICATIONS
ENGINE
Type TATA 483 DL TURBO
Bore / Stroke 83mm / 90mm
No. of Cylinders 4 inline
Displacement 1948 cc
Compression ratio 21 : 1
Max. engine Output 90 PS at 4300 rpm as per DIN 70020
Max. Torque 19 mkg at 2500 rpm as per DIN 70020
Air cleaner Dry (Paper) type
Oil Filter Spin-on full flow paper type
Fuel Filter Two stage, fine filteration
Capacity of cooling system 10 litres (Approx.)
Oil sump capacity 7.7 litres
Weight of engine (complete) 220 kg (Dry)
Radiator frontal area (core area) 2340 sq. cm.
CLUTCH
Type Single plate dry friction diaphragm type
Outside diameter 228 mm
GEAR BOX
Model G-76-5/3.87 with overdrive
Type Synchromesh
No of gears 5 Forward and 1 Reverse
Gear ratios 1st -3.87 2nd -2.22
3rd -1.37 4th -1.00
5th -0.82 Reverse -3.40
TRANSFER CASE
Transfer Case With electrical shift arrangement mounted on gear box.
Drive Options
4 x 2 High Ratio 1:1
4 x 4 High Ratio 1:1
4 x 4 Low Ratio 1:2.48
FRONT AXLE
Front Axle Independently suspended with automatic hub locks.
Ratio 4.1 (41/10) :1
REAR AXLE
Rear Axle Semi-floating
Ratio 4.08 (49/12) : 1
STEERING
Steering Power Steering
Steering wheel dia. 400 mm Ratio 18.2 : 1
FRAME
Longer member size (mm)
Depth : 110; Width : 60 ; Thick : 3
Number of cross member 7
SUSPENSION
Spring Torsion bar at Front & Leaf spring at Rear
Anti-roll bar At both front and rear
Shock Absorbers Hydraulic double acting telescopic type
BRAKES
Service Brakes Vacuum assisted hydraulic dual circuit with tandem master cylinder. 'G' conscious pressure reducing valve provided for rear brakes Front Brakes Disc brake
Rear brakes Drum brake
Total braking area Front : 199 cm sq.; Rear : 574 cm sq.
Parking Brakes Cable operated, mechanical on rear wheels.
FUEL TANK
Capacity 65 litres
ELECTRICAL SYSTEMS
System Voltage 12 Volts, (-ve ground)
Battery 12 V,N 70 Z
Alternator (max. output) 65 Amps type With built-in regulator
Wiper 2 speed with intermittent wiping
WHEELS & TYRES
Wheels 5.5 J x 15
Tyres 195 R15 8PR LT/215/70/R15C
DIMENSIONS
Wheelbase 2400
Overall width 1780
Overall length 4450
Front track 1500
Rear track 1450
Min. ground clearance 160 (Laden)
WEIGHTS (kg)
Max. GVW 2710
Max. Permissible FAW 1050
Max. Permissible RAW 1670
Kerb weight (with spare wheel, tools, full tank) 1900
Max. gradeability in 1st gear 65 %
SEATING CAPACITY
Capacity 9 + Driver
WARRANTY
CAUTION : Do not weld or drill on chassis frame
The specifications are subject to change without notice. Please contact our nearest office for latest specifications.
Data published herein is statistical and for information only, performance may vary with the conditions encountered.
FourWheelDrift is offline   (1) Thanks
Old 22nd June 2015, 13:41   #352
Thanked: 2,999 Times
Seems to be old pages. Go back and you see Tata Estate and Tata Seira, vehicles long discontinued. Any way, you can contact them here
http://www.mpallonjigroup.com/psterling/
Aroy is online now
Old 22nd June 2015, 17:50   #353
arjab's Avatar
Thanked: 6,544 Times
Originally Posted by FourWheelDrift View Post
Hello all,
I doubt dealer's will accept a booking as very few of them are aware that a 4x4 version of the Sumo exists.
Incidentally, TML also does not push the Sumo 4x4 into the civilian market much (a lost opportunity?).
4x4 Sumo's are usually preserved for fleet sales to Army, Army Ambulance and specific Govt agencies.
Your best bet will be to approach the Regional Sales Office of TML in your city and contact the person responsible for Institution & Defence Sales. As far as i know, they can approve on a case by case basis and allocate a piece to a dealership.
Also it may be worthwhile to check on the financing angle, in case you are planning to take a loan for a potential purchase. As the Sumo 4x4 is not on the "regular" list of cars, most banks are loathe to finance it!
arjab is offline   (1) Thanks
Old 14th May 2016, 12:16   #354
jeepster's Avatar
Thanked: 2,075 Times
Re: Updated Mahindra Thar in 2-3 months. EDIT : Launched with Air-Con and immobilizer
Originally Posted by Parm View Post
The Sumo is actively doing the Rally scene and participating and making podium finish!
Guys, consider this a teaser and the Competition is Hotting up! (SWB SUMO 4x4)
Tata Motors Full Throttle rallied home to victory in the 10th edition of India’s longest and one of the toughest off-roading events, the Desert Storm 2012 rally. Tata Motors took the honours with the new Tata Sumo Gold bagging first place, driven by Mr. Ganesh Moorthy and co-driver Mr. T. Nagrajan, followed by Mr. Sanjay Ram Takle and co-driver Mr. Mohd. Mustafa, winning third place in the Tata Sumo Grande. The 6-day long Desert Storm rally, often referred to as the mini Dakar rally, is the longest and amongst the most challenging rallies in India. Flagged off from Ahmedabad, on 20th February, 2012, the rallyspanned a grueling 3500 km through the Rann of Kutch, Bhuj, interiors of Rajasthan through Barmer, Jaiselmer, Pokhran, Thar, Bikaner and Jaipur, before reaching Delhi. Besides the Tata Sumo Gold, Tata Motors’ UV portfolio comprises the the premium Crossover Tata Aria, the Tata Safari 4x4, the Tata Sumo 4x4, the lifestyle pick-up Tata Xenon XT.
Dear Parm - thanks. "That Sumo" is MH01BB4972! .
Sad end of MH01BB4972 .
I would have bought it but sadly it was 4x2.
jeepster is offline
Old 18th May 2016, 14:09   #355
Thanked: 1,063 Times
MH01BB4972 - This is a "normal " 2 wheel drive sumo , with no additional mechanical changes .
I know , since i was the scrutineer for the Desert Storm rally , in which this car participated
The category that it participated is called "xplore : and it has normal road going cars as petrticpants - The year that this came , we had Altos and swifts on the same track
wbd8779 is offline   (4) Thanks
Old 22nd December 2016, 10:57   #356
jeepster's Avatar
New Sumo 4x4 spotted at Coimbatore.
Tata Sumo four-wheel-drive-15590283_1216343261778520_4177374623529629198_n.jpg
Tata Sumo four-wheel-drive-15589742_1216343308445182_6389705533646321017_n.jpg
Tata Sumo four-wheel-drive-15665655_1216343291778517_1376237657988339599_n.jpg
Tata Sumo four-wheel-drive-15621856_1216343235111856_1454624348419971508_n.jpg
Tata Sumo four-wheel-drive-15590434_1216343255111854_5916139170328342198_n.jpg
Source : Vipraajesh N G on FB
jeepster is offline   (8) Thanks
Old 25th December 2016, 18:06   #357
jeepster's Avatar
More pics.
Tata Sumo four-wheel-drive-15665466_1221318597947653_2234647742511798290_n.jpg
Tata Sumo four-wheel-drive-15672871_1221318631280983_6603951133746339908_n.jpg
Tata Sumo four-wheel-drive-15747517_1221317987947714_7896415100679930873_n.jpg
Tata Sumo four-wheel-drive-15665837_1221319101280936_4773862200744610073_n.jpg
Tata Sumo four-wheel-drive-15726738_1221319764614203_8601931544642605818_n.jpg
Tata Sumo four-wheel-drive-15698026_1221319917947521_1523867570465479061_n.jpg
Tata Sumo four-wheel-drive-15747571_1221320024614177_946895995490998234_n.jpg
Tata Sumo four-wheel-drive-15726395_1221320757947437_3185545820488059287_n.jpg
Tata Sumo four-wheel-drive-15697265_1221320737947439_3466036673153579293_n.jpg
Tata Sumo four-wheel-drive-15672865_1221321117947401_3367718888200304897_n.jpg
Tata Sumo four-wheel-drive-15726224_1221321454614034_3015220544637378168_n.jpg
Tata Sumo four-wheel-drive-15726944_1221321564614023_1991741155663003835_n.jpg
Tata Sumo four-wheel-drive-15698172_1221321594614020_263496679158247414_n.jpg
jeepster is offline   (7) Thanks
Old 28th December 2016, 17:33   #358
1100D's Avatar
Thanked: 4,116 Times
This is the old Safari BSIII 1995cc Indirect Injection TCIC engine. I guess this was always available on order from the commercial division.
However, Army has the 3.0 Dicor engined ones (The Ambulance) with the larger wheels, which has not been made available to the civilian market.
1100D is offline
Old 28th December 2016, 21:01   #359
4x4addict's Avatar
Definitely the older 2.0 IDI engine. I live in Niligiris and Poliice dept has a number of these older 4WD version. As you correctly pointed out Army ambulance the the 115 bhp Dicor engine from the previous Safari.
Old 3rd January 2017, 15:41   #360
Thanked: 568 Times
More pics.
Hi Jeepster,
Any word from Vipraajesh regarding how he ordered the vehicle, what it's on road price is and how it drives ?
What is strange for me is that the vehicle doesn't seem to have any form of forced ventilation system.
Cheers,
FourWheelDrift
