Originally Posted by GrayBerry Nice thread. I have plans to build a gen set as well, wanted to couple a hero Honda splender engine to an alternator! |
Thanks to you , ( I suddenly started thinking on scooter ,motorcycle engines , particularly having a cooling fan of its own ) I have almost reached conclusion about engine choice.
This will be a Kinetic Honda scooter engine
Features .
1) single cyl. two stroke .( less maintenance as lesser parts )
2) 100 cc ( 1 hp approx ), some 7 bhp @ 5000 rpm.
3) most importantly it has forced air cooling of its own ( a fan on crank ),unlike the motorcycle engine ( they are cooled when on move, by oncoming wind )
4) transmission can be separated easily. to use only crank pully.
5) added advantage, has a self starter . ( uses a much less current ,even a downed Jeep battery can start it )
most importantly ,it will be lot cheaper .( for such experiments )
will be posting developements BHPians, in & close to Pune , please tell me about any old kinetic honda for sale around you .
Sudarshan
P.S. @ Gray Berry, dont use motorcycle engine, as cooling will be a major issue if kept stationary . Also you cant separate the Gearbox ,its kind of Monoblock assembly . |
