Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 20th May 2010, 21:54   #31
gsferrari's Avatar
Thanked: 1,954 Times
I just realized there is no way I can get into Kunal's driving seat without cutting a hole in that roll cage
gsferrari is offline
Old 21st May 2010, 14:17   #32
Tejas@perioimpl's Avatar
Thanked: 9,688 Times
Arka,
As per our telephonic conversation the other day, you told me that there is a rubber bush below the lower part of the hinge which may be worn away.
I can't seem to find it, where should it have been? See attached pics:
Tejas@perioimpl is offline
Old 21st May 2010, 14:37   #33
fazalaliadil's Avatar
Thanked: 675 Times
Tejas,
It is this (arrow) which is actually a pvc sleeve between the metals, it is colored red, peel it off and you can see the black underneath.
You should have one at the top end and one at the bottom for metal to metal vibrations to dampen.
fazalaliadil is offline
Old 21st May 2010, 14:40   #34
Originally Posted by fazalaliadil View Post
Tejas,
Thanks a lot. Shall check and change both.
Old 21st May 2010, 16:30   #35
motocamp's Avatar
Thanked: 102 Times
It wasn't built with your dimensions in mind
By the way gs can you pm me your number?
motocamp is offline
Old 22nd May 2010, 21:37   #36
Thanked: 88 Times
Originally Posted by motocamp View Post
That is the tailgate
I prefer to have it like that but you could have the stock tailgate and the swing away one behind it.
Oh cool .
Yea i would like get one made with the stock tail gate and the swing away behind it but then the Swing away would need to clamp onto the tail gate right? wont that cause vibrations?
What was the cost involved to get this fabricated.
davids4x4mm550 is offline
Old 26th May 2010, 22:55   #37
narendra.vw's Avatar
Thanked: 425 Times
What I had to my relative jeep,
Firstly I removed both the hinges got thicker bushes made in brass, behind the jeep body where hinges fixes, I fabricated 6mm thick and 2inches wide plate. This plate was welded to the body. Care to be taken to fill the gap with rubber sealant between plate & body avoiding rust. Next, near the locking side, at the bottom of door fix a wooden piece to the body.(width 2”,bredth 2”, length 5”) I prefered teak. This stopped sagging & rattling of the door.
narendra.vw is offline
Old 16th June 2010, 13:30   #38
AVR
AVR's Avatar
Thanked: 865 Times
Problem solved (KISS style)
Guys,
A rather simplistic solution worked for me. Rattling of the tailgate primarily happened due to the play/extra space in the small hole where the lock part fits in. Just added two thick rubber linings on both ends (towards tyre and towards lock) running vertically and it seems to have solved the problem pretty well. Not sure if the solution was going to be so simplistic but in the short term it does look like it.
Cheers,
Adi
AVR is offline
Old 17th June 2010, 18:24   #39
testdrive's Avatar
How effective are the lever locks used on Rally Gypsies? Has anyone tried this option?
See pics...
1. Rear View
http://www.team-bhp.com/forum/attach...0-dsc01878.jpg
2. Front View
http://www.team-bhp.com/forum/attach...0-dsc01884.jpg
testdrive is offline
