Here are some of the learnings I have had during the execution of the SPoA Stage-1 project. Sharing them here so that people who go down this path can benefit from it.
- Find a garage/workshop that you are 100% comfortable with. It can be anywhere and any kind of workshop. Important thing is that both you and the workshop technician and should be talking the same language and understand each other. In my case, I am was 100% comfortable with Suraksha doing this job and trusted them.
The above is important as SPoA is > 90% a mechanical/labor intensive job and a lot depends on the skill and understanding of the person executing the job.
- Critical parts modified/altered:
- Spring Perches/Mounts
- Shock Mounts
- Brake Lines
- Steering (Drag Link. Not so much the tie rod)
- Propeller Shaft
Make sure that you have plans for each of these. It may sound easy, but getting these parts off the shelf or fabricating them is NOT easy. I found it during my project.
Spring Mounts: I was plain lucky that we could reuse the stock mounts/perches. If anyone of these had been damaged then I would have had a tough time getting the mounts fabricated. However, I have heard that for MM vehicles you get aftermarket perches. Don't k now if they will fit a Gypsy axle.
So be VERY careful with the mounts and your strategy for these. Also, the front driver side mount is of different size than rest.
Brake Lines: These have to be lengthened for SURE. I realized that in city one can get away with stock lines but in off-road even my lengthier pipes were being tested.
The issue one runs into getting new pipes is that usually no one keeps stock of extended brake lines as it is a part that rarely requires attention in most vehicles.
BTW, for a Gypsy, wagonR brake lines give 6-7" more length than stock Gypsy pipes.
And yes, the above just addresses the front brakes. You still have to worry about the rear brake pipe (single only).
Steering: Surprisingly, steering for Gypsy in SPoA with stock parts did not have much of an issue. However, if you plan to use bigger leafs then this is one things you have to plan for. Of al the things in SPoA, this is the most complex and can be most difficult to fabricate. However, you have options to do a z-link or a cross-over (only the drag link is above the leafs) or a hi-steer (both drag link & tie rod are above the leafs).
Propellor Shaft: This would be known only when all parts are assembled back together and you get to know how much splines are visible in the DS. Depending on that you may have to fabricate DS spacers or arrange for a longer prop shaft. Again, for me it's only ~1" of splines showing up (out of ~3.5") so am ok for now. But yes, it would be better to have spacers or a longer prop shaft.
Will keep adding to the learnings as I progress further.
Cheers,
