Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 17th December 2008, 10:28   #31
DesertKing's Avatar
Thanked: 24 Times
Originally Posted by whicked wheels View Post
Hi guys, just got the gearbox assembly fitted last night. I also changed my 4wd shifter setup from a two leaver to a one leaver set up found in a mm550.
Can you please let me know that how much did the single lever accembly cost you.
DesertKing is offline
Old 17th December 2008, 21:15   #32
whicked wheels's Avatar
Thanked: 83 Times
Hi deasert king, the single leaver assembly consist of these parts.
1] the mount bracket assembly; Rs 1650/-
2] the shifter leaver; Rs 400/-
3] the tension plate ;Rs 550/-
The mount bracket plate is a bolt on fitting with all the parts of the double leaver assemble. The tension plate has a mounting hole on the new bracket. Its basiclly easy to fit, just a few problems my shifter bracket bearing mounting hole and the front output shaft oil seal hole had to be machined out by 1mm as there was a fault in it. The other thing was that when the tension plate is fitted it colides with the clutch shaftand does not allow the clutch to operate, so for now i have just removed the tension plate for the clutch to operate. Ill be talking to a friend who works in mahindra about it. i think i might have to change to a cable set up for the clutch.
whicked wheels is offline
Old 18th December 2008, 15:42   #33
Parm's Avatar
Thanked: 898 Times
congrats on becoming a JEEPER. must say the jeep is turning out into a nice shaped jeep and that with with minimum body modifications.
nice to see the jeep getting your personal attention in its 2nd birth.
way to go jeeper!
cheers:
Parm is offline
Old 18th December 2008, 15:43   #34
Parm's Avatar
Thanked: 898 Times
those mudzilla are expensiver at 8500rs each!
Parm is offline
Old 7th March 2009, 17:07   #35
badboyscad's Avatar
Thanked: 480 Times
*BUMP*
Any updates? Is the wicked offroader ready yet?
badboyscad is offline
Old 7th March 2009, 18:02   #36
gd1418's Avatar
Thanked: 729 Times
I was waiting for the pics of the 4WD tranny assembly...
gd1418 is offline
Old 8th March 2009, 09:20   #37
fazalaliadil's Avatar
Thanked: 675 Times
Wicked wheels,
Great job being done on your 540, Your passion shows all the way.
Paint looks superb with the dull finish and also good body line, wish you had picked up 16" mudzilla's, or anyother, the 16 inchers make a huge difference in the overall look. All the best.
fazalaliadil is offline
Old 9th March 2009, 16:05   #38
Ricky_3007's Avatar
Thanked: 23 Times
Hey Whicked wheels ,
You have not updated this thread since Dec 08?
Is your Jeep Work completed? Pls update with pics.
BTW where do you stay in Pune? Your Vehicle shows MH14 no. you are in PCMC area?
Tarkesh
Ricky_3007 is offline
Old 9th March 2009, 17:21   #39
wanderernomad's Avatar
Thanked: 1,279 Times
What is the update? Wicked be nice and let us have the latest pictures and updates please.
wanderernomad is offline
Old 12th March 2009, 13:05   #40
pole_position's Avatar
Congrats on the Jeep and way to go with restoration process
Also, awaiting new info and pics.
pole_position is offline
Old 20th March 2009, 17:56   #41
Thanked: 83 Times
Sorry guys kept u waiting toooooo long, had some personal stuff going on. The jeep is done and also tested its off road abilities. Just some small stuff left to do. Here are some photos during the test drive we had.
Old 20th March 2009, 18:03   #42
badboyscad's Avatar
Thanked: 480 Times
Wow,looks good. Those MT tires sure add character to your jeep.
Old 20th March 2009, 18:15   #43
Thanked: 83 Times
Some more photos offroading. She (the jeep) performed well did not push her hard as this was the first time.
Old 20th March 2009, 18:17   #44
Spitfire's Avatar
Thanked: 777 Times
Wicked Maann...
Who is that pony with Recaro's in a open Jeep?
Spitfire is offline
Old 20th March 2009, 18:31   #45
Rotorhead's Avatar
Thanked: 29 Times
your jeep sure looks wicked dude. Those mudzilla's are damn hot and probably one major factor to make your jeep mean and macho . Nice lookin jeep in the background too.
Rotorhead is online now
