Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 1st August 2008, 12:17   #31
Samurai's Avatar
Thanked: 49,590 Times
Mr.Dhabhar, should I also disconnect the overflow tank, it was a recent addition.
Samurai is offline
Old 1st August 2008, 12:36   #32
Thanked: 5,406 Times
Just post all photographs, let me see them. Also please refer my posts in the Premier Padmini technical information thread in the vintage and classic cars section of the forum. I will guide you in totality. Don't do anything in haste. Also less oil in your front axle clearly indicates that the previous owner had not cared for the car just sold it to you. Be careful.
Best regards,
Behram Dhabhar
Last edited by DHABHAR.BEHRAM : 1st August 2008 at 12:38. Reason: Extra information
DHABHAR.BEHRAM is offline
Old 1st August 2008, 12:36   #33
headers's Avatar
Thanked: 563 Times
No need to disconnect the overflow tank. But having the correct pressure radiator cap helps you diagnose the problem better!
headers is offline
Old 3rd August 2008, 23:26   #34
Samurai's Avatar
Overheating problem in Jeep
Today I did a uphill run with the Jeep with just water in the radiator. It overheated up after just 10-15 minutes of uphill climbing and later hit 100C even in pouring rain. But on the return drive (downhill), it never crosses 60-70C.
Read the full test report here: http://www.team-bhp.com/forum/travel...mbe-ghats.html
Since it overheated in pouring rain, the problem may not be with radiator at all. I am getting really confused now.
Samurai is offline
Old 3rd August 2008, 23:57   #35
tsk1979's Avatar
Thanked: 23,484 Times
Is it possible that the water pump is not circulating the water fast enough?
tsk1979 is offline
Old 4th August 2008, 00:09   #36
susan3004's Avatar
Thanked: 268 Times
The overheating seems to be because of clogged water channels. The quantum of water/coolant is not flowing through them which is required to keep the engine temp in control.
This problem arises when avehicle is not used for a long time with the liquid still in the radiator.
susan3004 is offline
Old 4th August 2008, 00:28   #37
Thanked: 727 Times
just a wild guess! does the elevation of engine during climb and descend has anything to do with the flow of coolant/water in this particular jeep. Failure of pump can also be the case,
SirAlec is offline
Old 4th August 2008, 08:34   #38
Samurai's Avatar
I had the mechanic check the water pump, he didn't see anything out of ordinary. BTW, there is no thermostat.
I use it regularly, also the radiator core is new.
Samurai is offline
Old 4th August 2008, 08:50   #39
headers's Avatar
Thanked: 563 Times
There is no load on the engine while coming downhill other than engine braking, thats why the overheating did not occur downhill.
OK, can you repeat the same stretch with water and coolant but a coolant ratio of 1:30 or something like that!
No SirAlec, the elavation of the engine during the climg has nothing to do with the cooling system IMO. If pump fails, water does not flow period.
Kindly add a thermostat. Your engine efficiency will improve! Also your overheating may come down. The thermostat as you are aware starts and stops flow of water in the system, whereas the radiator cools the water passing through it. One without the other may not give us a fair idea of the potential problem!
headers is offline
Old 4th August 2008, 09:33   #40
Thanked: 758 Times
I guess this is normal heating. Worst case is that engine / fuel system is due for overhaul. But, if it was a problem with the fuel system, your mechanic would have noticed by now. And there would be problems with FE and power.
Some mechanics - we call them "asans" loosely translated as 'guru' in Kerala - can understand the engine "health" by simply listening to it. A good old gen diesel engine will (depending on make) "crack" during the explosion / burning cycle. The sharpness of this "crack" will lessen as the engine wears off. Of course, this sould is rather dependent on condition of the exhaust tubes too. You can compare this yourselves, if you listen well to other jeeps. But somebody knowledgeable should tell you "this is a good engine" and "this is a bad engine", etc.
What does your mechanic say about the engine's health? And why don't you take a second opinion from another mechanic - only if you are so worried?
Lesser mortals like us will need a "compression" test. I guess the engine is in its last legs, and you will have to live with this heating issue till a major overhaul. BTW, does this engine have an air circulation vent anywhere on the engine block? This would be a long tube, 1/2 or 3/4 inches diameter, curving down. (heavy vehicles have this). If so, does "smoke" come out out of this vent? This is a sure sign of an engine becoming due for overhaul. This smoke is coming out through the vent after leaking through the piston rings.
BaCkSeAtDrIVeR is offline
Old 4th August 2008, 12:39   #41
Thanked: 57 Times
The overheating of these engine occurs when the engine is up for overhaul, I have been thru these situation a lot [have been thru 4 overhauls on my jeep].
Any ways it was a problem on these engines [have also confirmed it with the service guys] , I had an electric fan on my jeep, and it maintained the temperature. Try driving thru congested road [stop and go traffic] and see if the temperature goes up[beyond the 80deg mark] secondly if the engine is consuming oil, about 1 liter per 3000-4000 km than you will have to look at overhauling the engine.
The 2.1 liter engine lasts for about 1 lac km before needing an overhaul, if you want an engine with one crank start, some people go upto 1.3-1.4 lac km before overhaul, but thats with starting problems and that eats up battery life.
dinar is offline
Old 4th August 2008, 13:27   #42
Samurai's Avatar
My Jeep does start with one crank, even if I am starting after 2 days.
So it looks like I need that engine compression test done.
Samurai is offline
Old 4th August 2008, 16:08   #43
DirtyDan's Avatar
Thanked: 1,664 Times
I agree that it is a robust engine but it has one major drawback. Because Mahindra only offered it with the 4 speed tranny, the engine is always running at the upper band of it's rpm at speeds over 80Kms. This results in the rings wearing out prematurely.
Most people I know have had to do a minor engine job, i.e (top end only) between 80K and 90K kilometers. If I recall, you did change your final drive ratio to gain better top speed. That or the fact that your vehicle may have been spend most of its' life as an urban cruiser may explain the 1.4 lakh life of the engine. To be honest you'r is the first 2.1 liter engine that I know that has gone 1.4 lakh km without the top end engine job.
DirtyDan, The classic symptoms of the 2.1 needing a ring job:
1. Oil consumption..which you won't probably know.
2. Look on the inner side of the bonnet you will see oil stains of small droplets.
3. You will need the heater to start all the time, i.e even after the engine has warmed up to about 60 degrees.
4. You will see thick smoke under heavy accelleration.
Above is a quote from 4x4addict on another thread.
Sure looked like a viper to me, live and not over-heated.
DirtyDan is offline
Old 4th August 2008, 18:54   #44
Samurai's Avatar
Here is the radiator cap image requested by Mr.Dhabhar.
Samurai is offline
Old 4th August 2008, 19:53   #45
Thanked: 727 Times
So if the pump is fine. Radiator may be the culprit.
SirAlec is offline
