Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 9th May 2011, 09:36   #1201
Kandisa's Avatar
Thanked: 560 Times
re: The Offroad Rims & Tyres Thread
Originally Posted by harjeev View Post
IIRC Kandisa has 30/9.5/15 on the stock gypsy rims and not 31"
I did have 30X9.5 Dunlop GrandTrek A/T initially but then upgraded to the 31X10.5 Bighorns couple of months before the Leh trip.
And yes if I am not mistaken his tyres also foul the body on full lock too.
No Sir,it does not! And my jeep also has 57" OKBJ in front.
Kandisa is offline
Old 9th May 2011, 10:10   #1202
AVR
AVR's Avatar
Thanked: 871 Times
@Harjeev, had checked with Kandisa about that. Will having stock axles instead of the OKBJ impact whether the tyres foul or not? I believe stock axles are 53" and not 57".
AVR is offline
Old 9th May 2011, 14:37   #1203
4x4addict's Avatar
Thanked: 4,648 Times
@AVR. Stock axles are 51" and not 53". If you want to go for 31x10.5 you need to get good negative offset alloys or you will loose your turning radius as on full turns the tire will rub your chasis.
4x4addict is offline   (1) Thanks
Old 9th May 2011, 14:47   #1204
AVR
AVR's Avatar
Thanked: 871 Times
Thanks 4x4addict, Have already ordered for Bighorns. Will see how it works out with the regular steel rims and decide accordingly. Somehow just can't take to the looks of most alloys on a Jeep.
About losing turn radius on full turns, I believe there's a way of adjusting/limiting the turn so that it doesnt foul on full turns. Correct? Let me know if I can do that for the time being.
AVR is offline
Old 9th May 2011, 15:00   #1205
4x4addict's Avatar
There is a bolt that has to be adjusted to prevent tires from rubbing the chasis. But essentially you will have to move the bolt out to prevent tire rubbing and hence your turning radius will come down.
Old 15th May 2011, 21:16   #1206
4x4army's Avatar
Thanked: 96 Times
Hi Guys,
Has any one used this hancook dynapro MT tyres ?
size - 31x10.5R15
- Sanjay
4x4army is offline
Old 16th May 2011, 13:46   #1207
AVR
AVR's Avatar
Thanked: 871 Times
Originally Posted by 4x4army View Post
Hi Guys,
size - 31x10.5R15
- Sanjay
Whats the cost? Not seen on any Jeep on the forum IIRC. If they are VFM then probably worth exploring. Am assuming you went through this link :
Hankook Dynapro MT RT03 Mud Tire Reviews and check it up against the usual suspects like the Bighorns/Trepadors/Geolandars.
Cheers,
Adi
AVR is offline
Old 16th May 2011, 15:20   #1208
4x4army's Avatar
Thanked: 96 Times
It is Rs. 7850 + 12.5 % Tax / per tyre.
4x4army is offline
Old 16th May 2011, 15:41   #1209
beejay's Avatar
Thanked: 218 Times
Hi Guys,
size - 31x10.5R15
- Sanjay
Same tyres are running in a friends Cj3b. Its 235 though. Will try to get a picture, i think i have it somewhere.
Hi Guys,
size - 31x10.5R15
- Sanjay
beejay is offline
Old 16th May 2011, 16:34   #1210
4x4army's Avatar
Thanked: 96 Times
beejay,
are those Gypsy's rims ?
4x4army is offline
Old 16th May 2011, 16:50   #1211
beejay's Avatar
Thanked: 218 Times
beejay,
Yes 4x4, gypsy rims.
beejay is offline
Old 17th May 2011, 14:19   #1212
jeepster's Avatar
Thanked: 2,078 Times
size - 31x10.5R15
available in mumbai?
any other size available in 15" & 16"?
pm me the contacts.
jeepster is offline
Old 23rd May 2011, 10:41   #1213
discoverwild's Avatar
Thanked: 3,695 Times
Can anyone give me a fair idea as to what kind of mileage (kms not kmpl) we can expect out of
1. AT tyres
2. AT-S tyres
3. MT tyres
I have had HT tyres earlier and the mileage I got out of them on the gypsy was about 70K. Driving 70% city roads, 20% rural, 10% offroad.
discoverwild is offline
Old 4th June 2011, 23:10   #1214
Originally Posted by jeepster View Post
hi guys
these wheels are used by jeeps as well as samurais all over the world.
i don't think these are available new , please check second hand market in MUMBAI.
===========[*]Bolt Pattern 5 on 5.5 inch (139.7 pcd)[/list][/indent]sorry could not load the pics that i had.
Any idea of the price. Sir, may i get a plus offset in this pattern.
sumeshm is offline
Old 5th June 2011, 00:59   #1215
AVR
AVR's Avatar
Thanked: 871 Times
Re: Off Road Steel Drums
Any particular reason for a plus-offset requirement? Almost always, people go in for negative offsets when it comes to the Jeeps.
AVR is offline
