Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 31st March 2011, 08:51   #1141
beejay's Avatar
Thanked: 218 Times
re: The Offroad Rims & Tyres Thread
Originally Posted by sreejeshmp View Post
What is the best AT tyre under 7500.00 for Thar ? My Usage will be around 70% onroad and 30% offroad (also would like to join with you guys in OTRs).
is 245/75/R16 Pirelli Scorpion ATR a good choice ? I called up the dealer in Coimbathor and he told he can arrange the tyre. Price will be around 7000-7200.
- Sreejesh
I think SV Santosh is running these tyres on his CJ340. I am not aware of the performance.
beejay is offline
Old 31st March 2011, 09:08   #1142
headers's Avatar
Thanked: 563 Times
The pirellis are good. Go for it.
headers is offline
Old 31st March 2011, 10:56   #1143
Jaggu's Avatar
Thanked: 17,273 Times
- Sreejesh
Or look at Yokohama Geolander AT-S, they are one of the best all rounders, both off and on the road.
Jaggu is online now
Old 31st March 2011, 11:06   #1144
tsk1979's Avatar
Thanked: 23,484 Times
If you are going to do rocky terrains, go for something with tougher sidewalls, like the continental cross contact AT. Its a harder tire.
tsk1979 is offline
Old 31st March 2011, 11:08   #1145
sreejeshmp's Avatar
Thanked: 887 Times
Its time for a change so no to Geolander AT-Ss and BFGs.Lets see what are all the other options.
What about the tyre size is 245/75/R16 is ok ?
tsk1979,
It should be a good High way tyre with descent off road capability. For Serious OTRs I am planing some resoled tyre with MT tire type tread pattern.
sreejeshmp is offline
Old 31st March 2011, 19:06   #1146
Thanked: 885 Times
I don't think this is a good idea, please consider & think over the following
1) will retreaded tyres stand the
A ) low air pressure off roads
B ) the traction requirements wrt the sole coming off
2 ) danger of getting the damaged ( while off roading ) tyre blown when you are on road .
This doesn't sound good wrt reliability & tyre life ( may be ok with traction requirements )
Sudarshan
Sudarshan is offline
Old 31st March 2011, 19:45   #1147
SPIKE ARRESTOR's Avatar
Thanked: 1,545 Times
Fully agree on this^^. Sreejesh, tires are your vehicles only interface with the ground. Never take them lightly. We need to talk on this.
Spike
EDIT- Why are you searching for tires from now itself?
SPIKE ARRESTOR is offline
Old 31st March 2011, 20:11   #1148
Jaggu's Avatar
If you want different tyre's be prepared for some heart aches also There are not many reliable option out there in India. Cooper's are another good option but all the very best in sourcing them. BFG's i would not recommend unless you plan to do only rocks, they really are bad in mud which is what you will encounter most of the time.
Jaggu is online now
Old 31st March 2011, 22:17   #1149
sreejeshmp's Avatar
Thanked: 887 Times
Jaggu,
I am looking for a Good AT tyre with descent off road capability. I think MT tyres are not good for on road especially on high speeds. I can't compromise on road performance but off the road. The Only exception is the OTR Events Which I am not experienced yet.You mean SCORPIONS are not good enough?
Sudarsan,
resoled tyre are not that bad but your points are correct really don't know in the case of "low air pressure off roads" and the traction on sidewalls.
Spike,
I started locating the dealer who sells this tyres. What about the tyre size ?
- Sreejesh
Old 7th April 2011, 15:29   #1150
nikhil1300's Avatar
off road alloy wheels
i did not know where to put this thread moderaters pls move it to the right post
i am looking for this parttern alloy wheels for my gypsy can any one help me with it
nikhil1300 is offline
Old 7th April 2011, 20:04   #1151
vak
Thanked: 46 Times
Offroad Rims/Tyres Thread
I have fitted my New Bolero Di 4wd with Geolander A/T S in 31-10.5-15 size. I am planning to get some steel wheels (not alloys) with negative off-set in 15 inch size.
vak is offline
Old 20th April 2011, 17:23   #1152
beejay's Avatar
Thanked: 218 Times
Quick Clarification. What are the problems that can arise running 8.5 inch rims on 215 size tyres?
beejay is offline
Old 20th April 2011, 18:08   #1153
Jaskirat's Avatar
Thanked: 206 Times
Hi Vak,
Can you please let us know from where are you planning to get the Steel Wheels for the Bolero. Do you plan to get the Standard OEM Steel Wheel or something similar to the Brazilian Steel Wheels / Trailer Wheels?
Jaskirat is offline
Old 20th April 2011, 18:52   #1154
fazalaliadil's Avatar
Thanked: 677 Times
Jaskirat,
These are brand new ones, are they available?
Nikhil,
Not exact, but similar ones are dealer available on T- BHP classified, pic. and link below.
http://classifieds.team-bhp.com/buy-...8J-Alloy.html/
fazalaliadil is offline   (1) Thanks
Old 25th April 2011, 14:17   #1155
jeepster's Avatar
Thanked: 2,079 Times
215 section tyre on 8.5j rim/alloy is not recommended & its impossible too.
at most you can use 5.5j or 6j wheel rim/alloy. (6.5j is also over size for 215)
when you fill air in tyre/tube it applies pressure on the rims flanges.
if there is not enough pressure the tyre will rotate when you apply brakes.
or tyre will not rotate with rims when you want them.
see the video.
jeepster is offline   (1) Thanks
