Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 27th July 2018, 18:47   #1
SID2997's Avatar
Thanked: 55 Times
Tyre Deflators
Hi Guys, I was looking across the web for a tyre deflator. I have always felt the need for one during the occasional off-road stints in my Fortuner. Came across this great valve which can reduce the pressure to a maximum of 18 psi at one time. If anybody knows of some other product which is easily available in India, kindly throw some light upon the same.
SIDHAANT
Last edited by Gannu_1 : 27th July 2018 at 19:23. Reason: T fort > Fortuner + please use a space after a full stop or comma. Thanks.
SID2997 is offline   (2) Thanks
Old 29th July 2018, 00:16   #2
Vikram Arya's Avatar
Thanked: 2,295 Times
Re: Tyre Deflators
You can buy the ARB tire deflator kit from Amazon.
https://www.amazon.in/ARB-ARB505-Arb...+tire+deflator
Though priced a bit steep, it is a well-designed tool that has been used over the years by off-road enthusiasts all over the world.
Vikram Arya is offline   (3) Thanks
Old 29th July 2018, 12:09   #3
dhanushs's Avatar
Thanked: 11,470 Times
Re: Tyre Deflators
Hello,
Doesn't most good pressure gauges have options for deflating? Also, I consider counting the seconds and removing the valve stem to be a cheaper and better way.
dhanushs is offline   (5) Thanks
Old 30th July 2018, 10:02   #4
Thanked: 321,514 Times
Re: Tyre Deflators
Two related threads that might help you:
Portable Inflators
Places to buy 4x4 stuff
And a post from the 2nd thread:
Originally Posted by genesis View Post
For Mumbai folks:
Stumbled upon this shop/office in Opera House which sells Pressure Gauges, Inflator Deflators and all sorts of Automobile tools. (toolKits, garage equipment, spanners, jacks)
Great collection, good quality stuff and really nice and knowledgeable person running the show.
I bought a tyre pressure gauge (analog pencil type, imported one, extremely sturdy) but ended up browsing for a while. Gadget lovers paradise.
Industrial Machinery Tools Corp (IMTC)
15 Avantikabai Gokhale Street, Mumbai 400 004
Phone: 022 5635 6162
Contact person: Rupak
It is on the first floor of a building opposite Impala Motors. Looks like an office but they do sell retail stuff
GTO is offline   (3) Thanks
Old 30th July 2018, 13:59   #5
Thanked: 571 Times
Re: Tyre Deflators
Originally Posted by SID2997 View Post
Hi Guys, I was looking across the web for a tyre deflator. I have always felt the need for one during the occasional off-road stints in my Fortuner. Came across this great valve which can reduce the pressure to a maximum of 18 psi at one time...
These are preset deflators and you will need to re-calibrate them in regular intervals as they might end up deflating more or less than the preset pressure after a period of use.
Also, as they are preset, you cannot use them if you need to deflate more or less than this level.
The easiest way to deflate is to get one of those valve removal tools from your friendly tire shop and learn to remove the valve. If you are indeed friendly with them, you get them free of cost.
The first few times will be a challenge, but once you get used to it, it is a breeze. Just make sure that you do not lose the valve pin or carry few extra's, always.
HappyWheels is offline   (2) Thanks
Old 1st August 2018, 14:44   #6
Tejas@perioimpl's Avatar
Thanked: 9,764 Times
Re: Tyre Deflators
I use JTBrooks tyre deflators. Outstanding stuff.
Comes as four pieces. You dial the pressure you want on each and put it on the tyre valves and forget about it. It slowly releases the air (not as fast as ARB) but it gives you enough time to complete your other pre offroading checklist tasks and not constantly keep checking on tyre pressure.
Highly recommended.
http://www.jtbrooks.com/our-products.html
EDIT: i have this one (it's a screenshot from their website):
Tejas@perioimpl is offline   (1) Thanks
Old 2nd August 2018, 08:58   #7
nshankar's Avatar
Thanked: 95 Times
Re: Tyre Deflators
The simplest one seen till date is this one.
I use the JT Brooks and ARB. JTB is set for 15 psi for entry into sand and the ARB is used to for further reducing upto 9 psi when soft sand is encountered.
nshankar is offline   (2) Thanks
Old 2nd August 2018, 11:43   #8
Re: Tyre Deflators
Attachment 1786104
Actually that would be this!
Tejas@perioimpl is offline   (5) Thanks
Old 2nd August 2018, 17:05   #9
DirtyDan's Avatar
Thanked: 1,664 Times
Re: Tyre Deflators
I have the upgraded steel version. Less flammable. The flat end fits nicely in a tyre air valve. The sharp end does not need an air valve and can be inserted directly into a tyre, e.g. if your neighbor keeps parking in your driveway.
DirtyDan is offline   (6) Thanks
Old 30th October 2018, 21:24   #10
SID2997's Avatar
Thanked: 55 Times
Re: Tyre Deflators
Thank you everyone for the great advice. Sorry,I am a tad late. I have logged in to TeamBhp after a long time. I am thinking of getting the ARB as in my personal opinion there products have a great track record in terms of reliability.
SID2997 is offline
