Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 29th August 2016, 11:27   #1
cool_dube's Avatar
Thanked: 4,702 Times
How bad are M/T Tyres on the road?
Hi folks,
I am planning to change the footwear for my Gypsy and am considering a switch to M/T tires instead of the good old Yokohama Geolander A/Ts. My usage will be a mix of on-road (daily commute to work) and off-road (occasional off-roading). Given this, here are a few queries:
* How bad are M/Ts going to be on-road? I know handling will suffer but then on-road manners for the Gypsy are nothing much to write home about anyways However, will highway drives (at 80-90 kmph) be a concern? Braking issues?
* How long will these last with this kind of usage? I do not anticipate high running - maybe ~500 km a month.
Thanks in advance...
cool_dube is offline
Old 29th August 2016, 14:22   #2
starter's Avatar
Thanked: 930 Times
Re: How bad are M/T tires on road
What M/T options do you have at 215-75-R15?
Or, do you intend to up-size? (235-75-R15? or something even bigger?)
My 2 cents: Don't go with M/Ts unless you really need it.
starter is offline   (2) Thanks
Old 29th August 2016, 16:48   #3
Jaggu's Avatar
Thanked: 17,293 Times
What kind of offroading? Major off the road expeditions / challenges, or minor trail drives?
Ride will be as good as not having shockies on vehicle. Braking on dry will be ok, but in wet it can get hands full at speeds.
On a lighter vehicle like gypsy you should get 80-85% of life compared to normal tyres.
Very valid point since on a stock vehicle wider tyres will zap power.
Very worthy advice
Jaggu is offline   (3) Thanks
Old 29th August 2016, 17:02   #4
dhanushs's Avatar
Thanked: 11,463 Times
@OP. The real problem with MT tyres are that they create a racket at speeds. Also, wet grip will suffer. With bigger lugs you cannot expect AT like braking.
With ~500kms a month, they should last you their shelf life = ~25000 to 30000 kms.
dhanushs is offline   (2) Thanks
Old 29th August 2016, 21:25   #5
cool_dube's Avatar
I do not intend to up-size beyond 215. I thought Yoko Geo M/Ts are available in this size. Is it not so?
Minor trail drives for to begin with but stuff like BAOTR is not ruled out.
Now that's a concern. This is what I was apprehensive about.
I am okay with the noise but braking issues in wet would be a deal breaker I guess.
Old 29th August 2016, 21:35   #6
starter's Avatar
Thanked: 930 Times
I have not been able to find any in 215s. I could find some options in 235s.
However, maxxis website says that trepadors are available in the size 205-70-R15.
Oh ya, trepadors are uni-directional though..
Cheers,
Deepak
Old 29th August 2016, 21:42   #7
karan561's Avatar
Thanked: 23,014 Times
@ cool_dube,
I think you should also look into BF Goodrich as they are available in the size you are looking for, also many Gypsy's i have seen have those tyres. They look really aggressive (almost like an M/T) but are an A/T type.
How bad are M/T Tyres on the road?-128265.jpg
http://www.team-bhp.com/forum/4x4-ex...tml#post785793
^ Check this post of a fellow BHPian
karan561 is offline   (3) Thanks
Old 29th August 2016, 22:05   #8
starter's Avatar
Thanked: 930 Times
Hey Karan,
I had them on my Gypsy too. Here is a click http://www.team-bhp.com/forum/attach...-deepu-026.jpg
They have some really strong side-walls but are quite bad in slush.
Yokos still seem like a better choice than BFGs.
Cheers,
Deepak
starter is offline   (4) Thanks
Old 30th August 2016, 10:02   #9
Jaggu's Avatar
Stick to AT's they are more than enough, including BAOTR. You will have better ride, road grip and braking. Carry a tow rope for very serious stuff and ask friends to just tug you
Jaggu is offline   (2) Thanks
Old 30th August 2016, 10:38   #10
Samurai's Avatar
Thanked: 49,654 Times
Just stick to AT tyres for your kind of usage. Otherwise you are highly compromising on braking, road grip & ride comfort. Most of the offroad terrain can be done using AT, I always had AT tyres on both my Jeeps. I thought about MT many times, and then backed off when common sense prevailed.
Samurai is offline   (2) Thanks
Old 30th August 2016, 12:26   #11
cool_dube's Avatar
Re: How bad are M/T Tyres on the road?
Thanks folks, for all your inputs. Going by the overwhelming consensus, I have decided to stick to Yokohama Geolander A/T's for now.
cool_dube is offline   (1) Thanks
Old 30th August 2016, 12:54   #12
Shubhendra's Avatar
Thanked: 2,351 Times
Hi folks,
As everyone has suggested pros and cons of A/Ts, i have a different point of view.
If your driving is limited to 500 kms per month, i am pretty sure you are not going to take it for long drives and would be limited to local runs and OTRs which will again not be high speed runs (where MTs have limitation of noise and grip).
MTs do help in many situations in OTRs and take the vehicle's offroad performance to a notch higher.
You can try Maxxis Trepadors 235/75/15 they are cost effective tyres and good performer on highways. I have used them in 3 vehicles, including few out of state trips and umpteen OTRs. Especially in Gypsy they just work good.
SHubhendra
Shubhendra is offline   (1) Thanks
Old 30th August 2016, 15:25   #13
cool_dube's Avatar
Thanks Shubhendra. Are these available in 215 profile? I am not willing to put spacers or upgrade to -ve offset rims yet. Intend to stick to stock rims for now.
Old 30th August 2016, 16:32   #14
Shubhendra's Avatar
Nope, but you dont need to change stock disks. See below pic of one of my Jeep which has 235/75/15 Trepadors on Gypsy rims.
I luckily got 215/75/15 BFGoodrich MT in 2007 in Allahabad with a vendor, after that never saw MTs available in 215/75/15.
How bad are M/T Tyres on the road?-img_0408.jpg
Shubhendra Singh
Old 30th August 2016, 16:48   #15
Samurai's Avatar
Well, if you are getting swayed that way, do look at this comment.
Samurai is offline   (1) Thanks
