Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 9,650 views |
![]() | #1 |
BHPian ![]() | WorldWar Jeep/Truck/Military Vehicles Manuals Every Info You Want on WWII Jeeps. Mods Please make this as a sticky. I was/am still planning to build my own SWB Mutt, So on the search for the details of THE JEEP, I discovered few links that will give us all information on the Jeeps we have been restoring and worshiping. Find below the links that have nearly 2 GB of scanned manuals of all jeeps and other trucks that were used in the world war. Most of these manuals are all designated by numbers, you can find about these numbers in below in the write up. All USA WorldWarII vehicle manuals : This include jeeps, bikes and artillery vehicles HyperWar: U.S. Army Technical Manuals Complete compilation of WW2 MANUALS including fuel pumps, and trailers JeepDraw Home Page Index Categorized part by part pics on World War Jeep. G503.com World War 2 Ron Fitzpatrick Jeep Parts For Sale All USA military vehicle technical manuals Internet Archive Search: subject:"Technical Manual" Complete information on World War JEEP Serial Numbers, Production Figures, & Models Archive Willys Overland and Ford Jeep Serial Number Page This Collection Includes All Of The Following Volumes of manuals. SNL G-503Willys-Overland Jeep World War II Model MB and Ford Model GPW Standard accessory spare parts lists, military Jeeps maintenance parts list, military vehicles spare parts list and equipment list, ordnance maintenance unit stock Willys Jeep parts list Willys Jeep Parts listing formerly listed in tm-10-1512 change no. 3, dated 1 August 1943. snlg503 SNL G-740 M38 Military WWII Jeep Willys 1/4 ton 4x4 Vehicle Parts Lists Military Willys Jeep Parts lists for engine, clutch, fuel system, exhaust system, cooling system, electrical system, transmission, transfer, propeller shaft, universal joints, front axle, rear axle, brakes, wheels, hubs, drums, controls, frame + brackets, springs + shock absorbers, fenders + hood, body, winch + power-take-off, bumpers + guards, miscellaneous accessories, ordnance + manufacturers' part number index + ordnance stock number index + federal stock number index and more. snlg740 SNL G-758 Parts Lists M170 M38a1 Military Truck Ambulance 1/4-ton 4x4 M170 surplus military truck, 1/4-ton, 4 x 4. List of military vehicle M170, M38a1 service parts including generator (24-volt) (auto-lite), generator ( 24-volt) ( delco-remy ), generator regulator (24-volt), starter, distributor, ignition coil wiring + spark plugs, instrument panel, miscellaneous switches, head, tail, + marker lights, auxiliary lights (M170), sending units, horn, batteries and more. snlg758 TM 9-803Jeep Willys-Overland Model MB - Ford Model GPW Part one-military surplus vehicle operating instructions 1/4 ton 4x4 military truck Jeep Willys-Overland model MB - ford model GPW)Part two-military surplus vehicle maintenance instructions 1/4 ton 4x4 military truck Jeep Willys-Overland model MB - ford model GPW) tm9-803 TM 9-1803a Willys Jeep engine Military Surplus Vehicle Technical ManualsMaintenance for surplus WWII military vehicles 1/4-ton 4x4 military truck Jeep Willys-Overland model MB and ford model GPW M38, M38a1, M151 , M151a, M151a2, M170, M718. tm9-1803a TM 9-1803bWillys Jeep Ordnance Maintenance: Power Train, Body, and Frame Willys-Overland Jeep model MB and ford model GPW 1/4 -ton 4x4 military truck, World War 2 technical manual 1944. tm9-1803b TM 9-1804a Willys Jeep M38 Repair and Rebuild - Engine and Clutch Jeep Willys Overland M38 4x4 World War II military truck this manual contains a description of and procedures for removal, disassembly, inspection, repair, rebuild, and assembly of the engine and clutch for the 1/4-ton 4 x 4 surplus Jeep M38. The appendix contains a list of current references, including supply catalogs, technical manuals, and other available publications applicable to the materiel. Department of the army June 1951. tm9-1804a TM 9-1804bWillys Jeep M38 Maintenance Power Train, Body, Frame 1/4 ton 4x4 This manual has procedure for removal, disassembly, inspection, repair, rebuild, and assembly of the transmission, transfer, axles, body, and frame for the 1/4-ton 4x4 military truck M38 references, including supply catalogs, technical manuals, and other publications departments of the army and the air force July 1952. tm9-1804b TM 9-2320-218-10Operators Manual for M151 , M151 a1, M151a1c, and M718 Operator maintenance of the four 1/4 ton, 4 x 4, Army Jeep models M151 , M151 a1, M151a1c, and M718 front line ambulance unless otherwise noted. Headquarters, department of the army march 1968. tm9-2320-218-10 TM 9-2320-218-20Maintenance M151 , M151 a1, M151 a2, M151 a1c, m718, m825 Military vehicle technical manual for organizational maintenance of the 1 / 4 ton,4x4, World War 2 Army Jeep M151 , M151 a1 and M151 a2 1/4 ton, 4x4, Army Rangers Jeep with 106mm recoilless rifle M151a1c, M825 and the ambulance truck M718 and M718a1. Them M151a1c and M825 vehicles mounts a 106mm recoilless rifle. The M718 and M718a1 vehicles are front line ambulance. The M151 a1c and M825 models are basically similar in design to the M151 , M151a1 and M151a2 vehicles. tm9-2320-218-20 TM 9-2320-218-20pMaintenance M151 , M151 A1, M151 A1C, M718, M718A1 Technical manual organizational maintenance repair parts and special tool list for military truck: 1/4 ton, 4x4, M151 (2320-542-4783), M151a1(2320-763-1092), M151a2 (2320-177-9258) 1/4 ton, 4x4, M151a1c (2320-763-1091), M825 (2320-177-9257), 106mm recoilless rifle truck, ambulance, front line: 1/4 ton, 4x4, M718, (2310-782-6056), M718a1 (2310-177-9256) tm9-2320-218-20p TM 9-2320-218-34Direct Support, General Support Maintenance Willies Jeep manuals 1/4 ton, 4x4 M151 (2320-542-4783), M151a1 (2320-763-1092) M151a2 (2320-177-9258) USMC Jeep: 1/4 ton, 4x4 M151a1c (2320-763-1091), M825 (2320-177-9257), 106mm recoilless rifle truck, ambulance, front line: 1/4 ton, 4 x 4, m718 (2310-782-6056), M718a1 (2310-177-9256). tm9-2320-218-34 TM 9-2800-1World War II Military Vehicle Descriptions 27 October 1947 This manual covers the ww2 army military vehicles illustration and dimensioned drawings of each vehicle are shown, with data including classification, purpose, characteristics, and performance ratings of each vehicle. Within the alphabetical arrangement, the transport vehicles are listed by increasing capacities and the combat vehicles are listed by increasing caliber of the major armament .in the index, however, the vehicles are grouped by types. tm9-2800-1 TM 9-2800Standard Military Motor Vehicle Descriptions Amphibians and landing vehicles, armored cars, scout cars, cargo and personnel carriers, self-propelled artillery, tanks, tank transport and recovery vehicles, tractors, ambulances, busses, passenger cars, motorcycles, trailers, semi trailers, dollies WWII. tm9-2800 TM 9-2815-237-34Direct / General Support for World War Two M151/a/a2 Direct support and general support maintenance engine, diesel: 8 cylinder naturally aspirated, fuel-injected, water cooled, DDA model 6.2 liter (nsn 2815-01-168-7892). tm9-2815-237-34 TM 9-2815-237-34pDirect and General Support for M151/a/a2 Diesel Engine 8cyl Depot maintenance manual direct support and general support maintenance engine, diesel: 8 cylinder, naturally aspirated, fuel-injected, water cooled, engine maintenance, repair parts, special tools, and support equipment, service upon receipt, troubleshooting tm9-2815-237-34p TM 9-8012Operator and Organizational Maintenance for M38 4x4 Military Truck M38 1/4-ton 4 x 4 military vehicle operating instructions, operation under usual conditions, organizational maintenance instructions, parts, special tools, and equipment for operation and organizational maintenance, lubrication and painting, preventive maintenance service, trouble shooting, and more tm9-8012 TM 9-8014Operator and Organizational Maintenance for M38a1 and M170 M38a1 1/4-ton 4x4 World War Two us military truck and M170 1/4-ton 4x4 front line ambulance operator and organizational maintenance description and data, operating instructions, controls and instruments, and more. tm9-8014 TM 9-8014c Changes to TM 9-8014 tm9-8014c TM 9-8015-1 Jeep Willys World War 2 Organizational Maintenance M38a1 Engine, Clutch Ordnance maintenance: engine Jeep Willys Overland model MD and clutch for 1/4-ton 4x4 us military truck M38a1 contains procedures for removal, disassembly, inspection, repair, rebuild, and assembly of the Jeep Willys Overland model MD engine and clutch. and more. tm9-8015-1 TM 9-8015-2Operator Organizational Maintenance M38a1 Power Train Body Frame This manual contains a description of and procedures for removal, disassembly, inspection, repair, rebuild, and assembly of the power train, body, and frame of the 1/4 - ton, 4 x 4 surplus Jeep special tools, and equipment for field and depot maintenance, trouble shooting, transmission, transfer case, propeller shafts, front axle, rear axle, brakes, springs and shock absorbers, steering system, wheels, disassembly of vehicle into major components, assembly of vehicle from major components, transmission data tm9-8015-2 TM 9-8015-2c1 Changes to TM 9-8015-2 Power train, body, and frame for 1/4-ton 4x4 World War 2 truck M38a1 and 1/4-ton 4 x 4 front line ambulance M170 this manual contains a description of and procedures for removal, disassembly, inspection, repair, rebuild, and assembly of the power train, body, and frame of the 1/4-ton 4x4 Army Jeep M38a1 the 1/4-ton 4 x 4 front line ambulance. tm9-8015-2c1 |
The following 6 BHPians Thank Twinn for this useful post: | ex670c, GTO, roy_libran, Samir Taheer, Shubhendra, Sudarshan |
![]() | #2 |
BANNED | Re: WorldWar Jeep/Truck/Military Vehicles Manuals Congrats A very commendable job you have done . I think I am seeing such things the very first time here additionally there is another search for the Internet archive site I tried Here ,check this Internet Archive Search: subject:"Military Vehicle" best regards Sudarshan |
The following 2 BHPians Thank Sudarshan for this useful post: | ex670c, Twinn |
![]() | #3 |
BANNED | Re: WorldWar Jeep/Truck/Military Vehicles Manuals Wanted to add one Important missed out No. TM - 10 -1513 change No. 1 May 15 1942 this is a 95 MB file ![]() Thanks for the M 151 Nos -- will check that ![]() Sudarshan |
The following BHPian Thanks Sudarshan for this useful post: | ex670c |
![]() | #4 |
BANNED | Re: WorldWar Jeep/Truck/Military Vehicles Manuals For all those M 151/ A1/A2 No.s this is the link . It seems that the Humvee is inspired as a enlarged & more advanced version of this M 151 type (?? ) the Link library m151 publication maintenance manual tm-2320-218 tm 9-2320-251 Sudarshan ![]() |
The following 3 BHPians Thank Sudarshan for this useful post: | ex670c, GTO, Twinn |
![]() | #5 |
BHPian ![]() | Re: WorldWar Jeep/Truck/Military Vehicles Manuals Special Thanks to Sudarshan Here is one more link: This link has a search engine that will pull out all the manuals of military vehicles. Just enter the number corresponding to the manual you'd like http://www.liberatedmanuals.com More Info on Kaiser Jeep Manuals TM 9 - 2320-244-10 Military Operators Manual M715, M725, M726 4x4 1.25 ton truck tm9- 2320-244-10 TM 9 - 2320-244-20 Organizational Maintenance Manual Military Cargo Truck 1 1/4 ton, 4 x 4, m715 m715, m725, m726 tm9- 2320-244-20 TM 9 -2320-244-20P M715, M725, M726 Manual Repair Parts and Special Tools oganizational maintenance tm9-2320-244-20p TM 9 -2320-244-34 Direct and General Support Maintenance Manual 1 1/4 ton, 4x4, m715 truck, ambulance 1 1/4 ton, 4x4, m725 truck, maintenance: m726 Contained herein are removal, disassembly, inspection, repair,overhaul, assembly and installation procedures normally beyond the scope of tools,equipment or supplies available to the using organization. tm9-2320-244-34 TM 9 -2320-244-34P Repair Parts and Special Tools Direct Support and General Support M715, M725, and M726 military trucks. tm9-2320-244-34p |
The following BHPian Thanks Twinn for this useful post: | Sudarshan |
