Team-BHP > Commercial Vehicles
Old 11th February 2018, 10:33   #1
Thanked: 24,093 Times
Greaves Cotton @ Auto Expo 2018
Big shoutout to Eddy for shooting these pictures & his coverage of the Auto Expo. Thanks for sharing, man!
Greaves Cotton Limited is an engineering company which manufactures diesel/ petrol engines, farm equipment and heavy equipment. It manufactures approximately 4,00,000 engines annually at their plants in Pune, Aurangabad & Ranipet. At the Auto Expo, the company showcased BSVI ready versions of diesel and CNG powertrains in 3-wheeler and micro 4-wheeler segments:
Here's the Eco2 - Pinnacle engine with linear twin piston technology. The engine is capable of running on CNG/ Petrol and has an all aluminium structure:
The 110 cc, 4-stroke, naturally aspirated engine is meant for 2-wheelers:
The engine has an opposed piston design and is capable of making 7 BHP @ 6,500 rpm and 9.1 Nm @ 5,000 rpm:
This alternative fuel engine is capable of providing equivalent performance to a diesel engine:
This is a water cooled engine and also has an all aluminium structure:
The single cylinder, 400 cc engine produces up to 12 BHP and 26 Nm of torque and has a port fuel injection:
The BSVI compliant engine has a single cylinder and is water cooled:
The 600 cc engine has common rail injection:
To be used in rickshaws, this engine is capable of making up to 12 BHP and 26 Nm of torque:
This Greaves engine is a slightly bigger version of the previous engine:
This is a 650 cc engine which makes up to 16 BHP and 40 Nm of torque:
It is water cooled and uses common rail injection:
This 3-cylinder, turbocharged engine, Intercooled (TC-IC) has 4 valves per cylinder and DOHC:
The specification sheet of the engine:
A few other views of the cut-out engine:
The stall also had information regarding “Greaves Care”, a shop for service needs:
Also on display was this 3W EV concept which has been designed and developed in India:
The powertrain solution and EV value chain is from Greaves and the vehicle body prototype has been designed and developed by MG Group:
Those are some tiny wheels for a big rickshaw:
The charging station:
A scooter like handle on the inside:
Small taillamps and indicators:
The EV powertrain which has been developed in collaboration with Altigreen propulsion systems is placed at the bottom:
Omkar is online now   (10) Thanks
Old 11th February 2018, 16:44   #2
Thanked: 80,000 Times
Re: Greaves Cotton @ Auto Expo 2018
Aditya is offline   (2) Thanks
Old 11th February 2018, 23:25   #3
Thanked: 71 Times
Hi Omkar - Thanks for the review - this is an under represented segment.
I have a query - you've mentioned that the 600 cc diesel engine ( used in the Tata Ace Zip?) is common rail - I was under the impression that only a multi cylinder engine can be called a common rail - can you confirm?
Skidrow is offline   (1) Thanks
Old 12th February 2018, 10:37   #4
I don't know the exact working of the common rail injection system in a single cylinder engines, although it is not uncommon.
After some searching found this answer -
It is possible to apply a common rail system at a small one cylinder diesel engine in general. You need a common rail pump, an ECU, connectors, tubes, and a suitable injector. In addition, sensors have to be applied according to the requirements of the control system. To save money, it makes sense to take a CR system from an existing serial engine. But it has to be clarified if the injector fits to the size and performance of the targeted engine.
Source
For confirmation, here's the product description. You'll notice that the bigger engine also is a single cylinder and gets Common rail injection:
Omkar is online now   (2) Thanks
Old 18th February 2018, 20:18   #5
Thanked: 6,227 Times
For me, the opposed piston engine (a 4 stroke) would have been one of the more interesting (which is entirely different from relevant) exhibits of the expo .
There was even a cutout model on display. But like womens' fashion from the masters, it teased and tantalised, but revealed nothing!
The engine is by Pinnacle, (a French company, if memory serves me correctly, but their site lists US and Indian contact addresses)
http://www.pinnacle-engines.com/technology/
who made some noise around 4-5 years back, but even their site has almost no technical details.
The person manning the exhibit was certainly better than the 'minders' at other stalls (one of whom confessed that they were there for crowd control, and keeping the (two legged) models safe), but technically way out of his depth. Ultimately he resorted to 'these details can only be discussed with OEs!' - a variation of the commonly used on our forum of 'confidentiality agreements prevent me from saying anything more'.
Sutripta
Sutripta is offline
