The console needles say hello to you with a full sweep. Though comprehensive, it has a crude feel to it. Please note that the trip computer is missing even in the top variant.
The top end variant gets a display having gear indicator, speed, and inside outside temperature. Mahindra calls it Digital Drive Assist System
![Shockked](https://www.team-bhp.com/forum/images/smilies/Shockked.png)
The usual micro hybrid system is present on the Quanto and works as intented.
Top end varient gets ABS+EBD with twin Airbags
Roof console with sun glass holder
Illuminated vanity Mirror
Courtesy Lamps and Reading Lights
Rear doors open really wide. Note the absence of bottle holders.
The foot well is wide and you get a dead pedal as well. Even size 9 footwear wont create any problems here. Also, long legs will be easily accommodated judging by the width.
Engine
THe quanto gets the mHawk engine minus one cylinder. Christianed the mCR100, this derivative is BS4 compliant and moves every quanto stepping out from the factory for the time being.
The twin turbo works in two stages, the smaller one comes in for lower rpms and the bigger and main turbo charger labouring for the rest of the rev range. The twin turbos as per Mahindra helped them extract 240 Nm of torque from the engine.
The ducting for the intercooler is pretty impressive and well executed.
The 3 cylinder engine does not feel like one in terms of vibrations and noise. Mahindra engineers have done a great job in damping and isolating the engine from the passenger compartment. Start the engine and you will be greeted by a distinct common rail clatter, but it soon settles down into a subtle idle. Yes, definitely, you will know that there is an oil burner under the hood, but the engine noise and vibrations will not affect you in an intrusive way at any point in the rev range.
A bit of turbo lag below 1500 rpm but after that the acceleration is pretty linear and progressive.
The 1650 kg kerb wight of the Quanto lets it down in a quick getaway and in traffic light Need for Speed. The car takes its own sweet time to hit the ton and doesn't feel eager. Overtaking won't be a pain, thanks to the rich torque reserve which is available for most part of the rev range.But the short gear, ratios mated and perfected for city rides make the Quanto run out of breath quickly at 3 digit speeds.
Gear Box
The gear shift felt rubbery and vague and has typical long throws for an SUV gear box. The ratios, as mentioned earlier have been mated keeping city runs in mind.
Ride Quality
The Quanto exhibits tall boy handling characteristics in a typical fashion. Tall profile, soft suspension, high profile tyres, as we all know never assists in giving us a decent handling. But the Quanto here is a criminal example for these handling characteristics. The Quanto makes sure that every second above 100 kmpH will be a hair raising experience for you. There is body roll and oodles of it. And undulations on your highway make it a cradle. The top heavy nature of the car makes it sloppy while changing directions. Mahindra should have spent more time on sorting out the handling.
Great Approach & Departure angles for a car of its size.
Build quality
The car looks built to a cost, but all the components seem built to last and hard wearing. The wiper/lights control stalks look hard and shiny but act precisely and click themselves into defined positions. The dash board is hard but the texture is good and looks rich as long as you don't touch. The cabin as such feels like its well put together and it feels like rattles should be away for some time at least.
Mileage
Now, down to the most important question. Mahindra advertises an ARAI certified mileage of 17.4 kmpl for the quanto which is no way going to be a segment topping figure in any category but is not so bad for a 1650kg car. We can expect a real world figure of 15 kmpl on the highway and 12 - 13 kmpl in the cities.
Variant Comparison
Pricing
All Prices Ex-Showroom (Kerala)
C2 - Rs. 6,09,856 /-
C4 - Rs. 6,64,184 /-
C6 - Rs. 7,16,604 /-
C8 - Rs. 7,68,814 /-
Conclusion
Altogether an excellent effort by Mahindra, but they should have spent more time on the crucial areas like suspension and weight reduction. Packing this much of car in 4 meters is no way an easy task and applauds to Mahindra for that.
Weight reduction should have been concentrated upon to extract much appreciated performance from the potent engine.
A firmer, well sorted out suspension would have added glory to the car.
And its quite curious that Mahindra didn't give the Quanto, the face lifted face of its elder sibling. The same would have given a fresher look to the Quanto. The rear end surprisingly looks good for a Mahindra.
The commanding view makes you feel that you are sitting in an SUV, and it also rides like one. Though it may ride a little bouncy over broken roads, it will still make it to the other end in one piece and also will do it better than most
hatches and sedans. So, people wanting something different from a regular hatch back, here is your ride. It has its own share of short comings but at this price tag, I don't see any other option in the radar unless Ford does some magic in the pricing of the Ecosport. Premier still refuses to go into the masses either with advertising or with dealerships. The other competent opponent, the Renault Duster, is priced way above the Quanto and has opened a different league for itself with its outstanding ride quality and great performance figures bringing cars from 2 segments above to a shame. But its difficult to justify the price tag of the Duster at this juncture. Yes, the Quanto has got its own significance in the market at this time and its worth going for a test drive and finding out by yourself whether this is the one for you.
TD Vehicle Courtesy: ITL Motors, Calicut
Photos Courtesy: Mr. Arun Venugopal
