Old 25th August 2011, 18:09   #106
Thanked: 21 Times
Re: A List of DIY's for your car: A Pictorial Guide
How can we adjust the headlight beams in ikon? My car went for the service and A.S.S guys screwed the headlight adjustment for right headlight. Now the headlight beam is pointing downwards.
I do not want to travel 10 KMs for just the adjustment and would like to adjust it myself.
pankaj_sachdeva is offline
Old 26th August 2011, 00:31   #107
dhanushs's Avatar
Thanked: 10,538 Times
Yes, the IKON's HL Focus can be adjusted up-down and left-right. There are two holes through which you can access the adjustment screws. As shown in the figure.
A List of DIY's for your car: A Pictorial Guide-adjustment-scre-location.jpg
The Adjustment Screw. Use an appropriate tool.
A List of DIY's for your car: A Pictorial Guide-screw.jpg
dhanushs is offline   (2) Thanks
Old 26th August 2011, 09:22   #108
Thanked: 21 Times
Many Thanks dhanushs for the pics. Let me give it a try on weekend and see , if I am able to adjust the beam up to my liking.
Old 12th September 2011, 10:34   #109
Thanked: 306,755 Times
Dhanushs,
As per your PM, I've added an index of all the DIYs on this thread to the opening post. Hope that helps! Thanks.
GTO is offline   (1) Thanks
Old 12th September 2011, 11:04   #110
mayankk's Avatar
Thanked: 8,285 Times
Is this open to all?
If so, here is my weekend work.
DIY : Front Brake pad replacement on ford fiesta(not New fiesta) , or how to save 400 bucks on labor.
What you need:
car toolkit(wheel removal bits).
Allen keys(number 7 or 11).
New brake pads
A flat head screwdriver.
Step 1:
Jack up the car, and remove front wheel.
Step 2:
A List of DIY's for your car: A Pictorial Guide-caliper-clip.jpg
Source:http://www.team-bhp.com/forum/test-d...ew-pg10-6.html
Insert Screwdriver at marked spots, and twist.
The clip will pop right off.
Step 3:
A List of DIY's for your car: A Pictorial Guide-allen-key.jpg
The arrow points to a hole, where you put in the allen key.
My keys are really old, and i couldnt read if it used to be 7, or an 11.
presumably, you will have the whole set.
Perpendicularly down wards from this hole, is another one for another allen bolt, remove in same way.
The whole caliper assembly will come off the disc now.
Do not struggle.
If it doesnt, try gentle rocking.
There will be some drippage of brake oil, so would suggest gloves, and a cleaning cloth handy.
Once it come off, its a matter of dropping out the old pads, and inserting the new.
Which will look like:
A List of DIY's for your car: A Pictorial Guide-clip-pad.jpg
The ones with clips go on the inside of the caliper, the ones without go outside.
Repeat earlier procedure in reverse.
For the clips, there will be a slight struggle, and is to be expected.
But go easy with all parts other than the pads, as replacements will entail a longish journey with the car to ASC.
Remember, if anything seems to taking more muscle than usual, there is something wrong that youre doing, or have forgotten.
Cheerios!!!
PS: After market pads will cost you onwards of 750 bucks a set.
OE would be around 1300 bucks a pop.
mayankk is offline   (2) Thanks
Old 12th September 2011, 12:17   #111
goandude's Avatar
Thanked: 1,288 Times
I
I dont think break fluid will drip while changing pads HowStuffWorks "Removing Old Brake Pads"
Moreover one has to get the piston to the "full open position" as the new pads will be thicker than the old ones. and you need a C clamp for this . a guide here How To Change Your Brake Pads - Edmunds.com
goandude is offline
Old 12th September 2011, 12:27   #112
mayankk's Avatar
ahh,there was a slight bleed from the hydraulic lines, when disconnected, which i forgot about.
Didnt need a C-clamp, the "full-open" happened.
mayankk is offline
Old 1st November 2011, 09:22   #113
ilangop's Avatar
Thanked: 912 Times
Rear roof lamp for Ford Ikon
Hi Dhanush,
Have you ever explored the possibility of having an additional roof lamp for the rear seaters in a Ford Ikon. The roof trim has a small rectangular depression near the high mounted brake lamp. As well the sheet metal inside is formed in a manner that it can accomodate a lamp similar to the front roof lamp. Just wanted to ask you if you ever happened to notice this.
Thanks,
Ilango
ilangop is offline
Old 25th November 2011, 11:26   #114
dhanushs's Avatar
Re: Rear roof lamp for Ford Ikon
ilangop,
Once more, thanks for the idea mate. I have a rear reading light in my car, and hence haven't really felt the need for rear lights. But now, the lamp is broken (from the workshop). I was planning on fixing it, but now I guess, I'll try the rear roof lamp set up.
Will update here for sure!
Thanks,
Dhanush
dhanushs is offline
Old 25th November 2011, 11:37   #115
condor's Avatar
Thanked: 16,241 Times
hi Ilango, pls check this:
http://www.team-bhp.com/forum/test-d...ml#post1986678
condor is online now   (1) Thanks
Old 2nd December 2011, 21:16   #116
Thanked: 175 Times
Cool post, quick query which brand of after market pads are these?
I have to change it for my fiesta, the prices seem to be same at the ASC and market approx Rs 1500.
Thanks.
cyberwhizs is offline
Old 4th December 2011, 08:51   #117
mayankk's Avatar
Thanks.
Hey cyber, these were supergrip, indian made.
compared to OE, they throw out much less dust.
But one thing though.
I had them checked the other day, and they seem to have left about half their life left now.
But then, Ford OE last me about 1/3rd more since i brake hard most of the time.
mayankk is offline
Old 15th December 2011, 03:44   #118
spiritofdriving's Avatar
Thanked: 28 Times
mayankk, Dhanushs
Looking fwd to the side panels opening etc - in my Fiesta, the side panels rattle on rough patches - Only in mine? Rattling has some relation to power windows I guess
Now I want to try opening it and checking this myself. Any help will be appreciated!
Thanks in advance
spiritofdriving is offline
Old 24th December 2011, 00:23   #119
Jaguar's Avatar
Thanked: 2,709 Times
Re: DIY: How to clean/replace Air Filter
Car: Ford Ikon Flair
Step 1: Remove Screws. As shown in the figure, remove the four screws that hold the filter box in place. As the location of the screws are a bit tricky, a magnetic screw driver might have a slight edge.
Attachment 571885
Could you tell me which screw driver/tool you used? I tried to unscrew these in my ikon today, but couldn't with the regular or star screw drivers. An allen key I have fits, but it is too short/small to reach all the screws.
Jaguar is offline
Old 24th December 2011, 02:25   #120
dhanushs's Avatar
Hey Jaguar,
I used the normal flat screw driver. Well, it worked in my case, as the air filter element is removed on every service, which happens in about ~4 months.
I'm sure with the right tool, it should be easy enough.
Dhanush
dhanushs is offline
