Re: Bajaj Pulsar 150 Classic - Restoration & Modification Quote:
Originally Posted by Mr.Boss ^^^ thanks ashis, I'm leaving the DC conversion as a future upgrade.
Guys, I have another query regarding the painting scheme. I have something in mind, please suggest
1) Shiny Black (OE) - Body (Tank / Shield / mud guard)
2) Matte Black - Front Fork, Rear swing arm, chain guard, engine cylinder & head, kicker
3) Silver (OE) - Crank case, foot peg bracket, T-stem top
Regarding the Silver, which one should I go for? Regular silver that came with this bike or the latest one (little golden shade) in UG4.5?
Also the engine cylinder and the head, should I go for Solver or Black? |
Some suggestions to your points:
1) How about changing the color? Latest trend of metallic white (Karizma/UG5/Ninja/Apache) or the Plasma blue of UG4.5 or the blue used in the Yam Gladiator SS? Though White will be prone to scratches.
I agree the Pulsar Black theme will give it ageless look.
2) Swing-arm and chain guard used to have dull black without clear-coat (not matt) in OE paint scheme. Matt might be easier to maintain in those areas.
3) The new silver (UG4.5) looks much better. Cylinder, head and gearbox again look best in black but the color is known to peel off due to heat if not painted properly.
Apart from this, I have a couple of more suggestions.
1) Try to look around for a used P200/P220 exhaust pipe (new ones used to cost around 7k). It would further improve the looks and performance. The "Exhaustec" technology was introduced UG3 onwards which improved the low-end performance significantly. I replaced my UG2's rusted silencer with a new UG4 black silencer (Rs3.5K) and the low-end performance was addictive.
2) I hope you have thoroughly cleaned the fuel tank and checked for corrosion. Pulsar fuel tanks are notoriously known to be the hiding place of water which corrodes it badly, sometimes irreparably. I learnt this the hard way when I flushed my old P150's tank after 5 years and was surprised to find almost 1 litre of water at bottom, below the petrol layer ![Shockked](https://www.team-bhp.com/forum/images/smilies/Shockked.png) . That along with almost a fistful of muck/rust and a leaking tank made me ![Frustration](https://www.team-bhp.com/forum/images/smilies/Frustration.gif) . The bike was running like a dream and gave no signs of danger.
3) Get the clutch and accelerator wires (with sheath) replaced as a preventive. Also replaced the front brake disc hose with that of a P220(one of the best available in the market). |
