The G30 5 Series
There were many suggestions to go for a new 530i. However, I had two issues. The first was that I had to stretch my budget by another 10 Lacs to get a 530i. The second concern was how the 530i would perform in the ride and handling department due to its longer wheelbase and higher weight. Because of this I had totally ruled out this option in the beginning.
However, @androdev was very persistent and was urging me to consider 530i as it was more practical, and finally SantoshBhat came up with that brilliant sales pitch that tilted me over.
The most important point the proponents of 530i had to say was that though the F30 330i would be a fantastic fun to drive car, it would actually be a downgrade in terms of space and practicality compared to the Jetta. Once the initial euphoria with the performace wears out, I could start missing out on the practical aspects on those long journeys with the family. Also, the G30 5 series is a completely fresh platform released only in 2017, whereas the F30 is going to be replaced by the G20 in early 2019. Because of this the G30 5 series will feel fresh for a long time to come.
I checked out many road test reviews over the weekend and almost all the reviewers had the same opinion – in spite of it being a luxury executive sedan, the 530i was a fantastic handler and did not feel its size at all. Many attributed this to its adaptive suspension and also the weight reduction due to the extensive use of aluminium.
Went to the showroom to check out the car. I must say, I was just bowled out by the looks. The car just looks FANTASTIC in black.
Checked out the rear legroom. With the driver seat set to my height, the rear legroom was quite adequate.
The boot also was adequate even with the space saver tire inside. They have created a nice compartment for the space saver. The space saver and this compartment can be removed for even more boot space.
Test Drive:
In the evening, the SA brought the 5 series (a 520D sport line) for a test drive. As it was late in the evening, had to limit the test drive to a short one of about 20km through some winding country side roads, and some stretches of rough patches.
The goods first:
Ride and Handling: One of my biggest concerns about the 5 series was its size and how it would behave in the corners. Surprisingly, as many reviewers have already said, the 5 series shrinks in the corners. It took the corners almost like a smaller sedan. So, I could write off that concern. Though it would still not be as agile as a 3 in corners, it was enough for my expectation (I need a car that has some balance between fun to drive factor and and practicality). Also, in the comfort mode, the suspensions were absorbing all but a few of the pot holes and rough patches in the road.
Rear bench comfort: More than enough leg room and rear bench comfort. Once I set the the drivers seat to my (I am 5’ 11”) comfort, I could comfortably sit in the rear seat without feeling cramped. As my children would be occupying the rear seat, this is more than enough.
Loaded with gizmos: The car is loaded with lots of gadgets - The large iDrive screen which is also a touch screen, fully digital instrument cluster that changes character based on the drive mode, electrically adjustable steering wheel. The car should feel totally fresh for the coming 7 years.
Now to the bads:
In fact, there is only one bad which almost irritatingly dominated the whole drive – the ground clearance. With such a long wheelbase, I was totally prepared for the car to hit speed breakers if taken at higher speeds. So, I babied the car on speed breakers (just I baby my Polo GT TSi with the coilovers and lowering). However, even when I almost stopped the car and crawled over speed breakers, the car was scraping even regular speed breakers. Both the front overhang and under-body were taking a hit.
What was most annoying was the SA who was riding pillion literrally stiffened up whenever I approached speed breakers (the same way I react when my wife approaches speed breakers on the Polo GT
), and was always telling me to slow down though I had already slowed down to a crawl. I could feel his discomfort. And he was repeating again and again that this car is meant for highways. Now this is a deal breaker. I always baby my cars when I approach rough patches of roads or speed breakers. But if the car is going to scrape in spite of this babying, then I am thinking this could take out the fun in driving the car. Though the car will be used primarily for long distance drives, I sure will have to pass through villages and towns filled with speed breakers!
But for this problem, I could have just booked the car! It was that good in all other departments. Maybe this is one of the teething troubles of bringing a new platform to India. Maybe BMW will do something about this in the upcoming batches like increase the ground clearance by a few millimeters or stiffen the suspension.
My question to others with experience with such cars:
Is this always the case with long wheel base cars? Should I expect it to scrape no matter how carefully I take speed breakers? How is the F10 5 series? Could this be because they have made the G30 longer than the F10?
So, for now, I am going to reserve my judgement till I TD a 3 series, hopefully next week.
Another thing to note: The SA is asking me to go for the 3 GT. However, I had done a TD of the 3GT and found it to have too much rolling, which should kill all the fun in the handling department. Other than that the GT is quite a good car.
