Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 51,666 views |
12th March 2013, 18:53 | #31 | ||
Distinguished - BHPian | Re: DIY : Throttle Body - Coolant bypass Quote:
Cars are designed for the masses with a very wide range of input parameters. The brutal truth is that most, if not all of us, fit into that framework perfectly. The way we drive our cars is nothing special. Not to offend anybody but we are discussing some pretty run of the mill cars here. And each owner will probably match the manufacturers profile in terms of performance specification down to income bracket for 99.9999%. Quote:
Only when you fully understand why the manufacturer put a heated TB in, can you start optimizing, improving. The rest is just trial and error and see what happens. I'm fine with that. It's just not the way I go about things. It's not that difficult to really understand why a particular manufacturer uses a heated TB. For starters most OEM workshop manuals would probably explain! So you do need to do a bit more research than googling the "net". It's not that difficult to get in contact with the manufacturers R&D engineers. Sometimes they do hang out on these sort of forums as well. But again, if you want to go ahead and bypass without understanding be my guest. All I'm saying I would do it differently. And yes, I have made various modifications to multiple cars I have owned. And unfortunately, no matter how I like to think I'm very special car-wise, I'm probably just one more in the masses of car owners. Enjoy your car and modifications, optimized or sub-optimized. Just don't be to upset because you're not special but just another data point in the masses for the car manufacturers. Bypassing doesn't change that. Jeroen | ||
(1) Thanks |
The following BHPian Thanks Jeroen for this useful post: | mmmjgm |
12th March 2013, 19:27 | #32 | ||||||
Senior - BHPian Join Date: May 2005 Location: Location
Thanked: 9,196 Times
| Re: DIY : Throttle Body - Coolant bypass The short green arrow points to the PCV hose which vent crankcase pressure and gases into the manifold. It is post throttle body. The long green arrow is the breather hose. Remove the pipes and see, if you don't see any gains put it back. Since the manifold is aluminium this TB alongwith the manifold is getting heated by the cylinder head. So to keep it cool insulating gaskets are also recommended. In my car the manifold is plastic so not much heat transfer. Quote:
You might say the difference is in semantics but there is a difference when you say EGR and PCV crankcase gases. Agreed that PCV crankcase gases will contain some amount of hydrocarbons and carbon alongwith oil mist but the quantity of carbon is not as much as in EGR. Both terms are not interchangeable. Both have similar constituents but neither are they the same nor is the proportion. And just to clarify one more thing, i was incorrect when i said the PCV in my car vents before the throttle body. Infact it doesn't and it infacts vent directly into the manifold. So no crankcase gases are going into the tb. Quote:
Once again i'm hoping that someone can tell me how i'm suboptimising and is not trying to tell me i should've stuck with what was dished out by the manufacturer since they know the best. When i did my "googling" found couple of instances when people who have done it said it did make a gain on the dyno. So far i didn't come across anyone doing this and saying it killed the performance. Yes i am enjoying the car, because for one it eliminated a flatspot which was prominent and two it is pulling better through the rev range. Quote:
() Thanks |
13th March 2013, 10:39 | #33 | |
Jeroen | |
(2) Thanks |
The following 2 BHPians Thank Jeroen for this useful post: | Gannu_1, Sankar |
14th March 2013, 08:19 | #34 | ||
(1) Thanks |
The following BHPian Thanks Sankar for this useful post: | Catalyst_delhi |
12th June 2013, 22:12 | #35 |
| Re: DIY : Throttle Body - Coolant bypass It looks like Maruti themselves has removed coolant circulation through the throttle body of the new petrol swifts rolling out of the factory. Nice This is the picture of the throttle body of my friend's May 2013 Swift VXI. There is no coolant circulated through the throttle body of this Swift and there is no T on the main coolant pipe to divert the coolant to TB and there is no return pipe for the coolant from the TB. The inlet and outlet on the TB remains. This was a surprise find since i was looking for something else in the engine bay. 2013 May Swift VXI - No Coolant through TB. No extra lines or T. 2012 April Swift VXI - Coolant flows through TB (In this pic it has been bypassed) |
(3) Thanks |
The following 3 BHPians Thank Sankar for this useful post: | Divya Sharan, Leoshashi, Rehaan |
